Air Intake Box Temp Sensor?
Old Jun 12, 2006 | 08:54 AM
wunderw1's Avatar
wunderw1
I have read alot of posts on installation of aftermarket intake systems, and didn't notice anything about what to do with the temperature sensor mounted on the stock filter box.
It looks like some kind of temperature sensor, and I did not know what it's effect on system is when other intake systems are installed.
Any input on this?
Old Jun 12, 2006 | 10:17 AM
DaBigTow's Avatar
DaBigTow
Just lay it off to the side. I stuck mine up against the fender well. It will read the unerhood temp next to the filter, which is what it used to do.
Old Jun 13, 2006 | 04:21 PM
believer45's Avatar
believer45
I wire tied mine to one of the inner fender braces on the driver side fender when I did my open element intake, it works fine.
Dave / Believer45
Old Jun 13, 2006 | 06:11 PM
plowhand's Avatar
plowhand
Playing in the Dirt
You can also take a piece of sheet metal and make a "L" shaped bracket, drill a hole big enough for the sender on the long part and a hole for a bolt on the short part and mount it to a support bolt on the inner fender well.
