Dash Blinker Light is out on my 72?
My left blinkers are working -front and back- but my left dash blinker light went out yesterday. Does anyone know how that's replaced...just take off the dash cover?
Also maybe someone knows this too - my dash lights have always been sorta dim. Should I replace the light bulb(s)? with the recommended bulb(s) now too, or is there a stronger bulb I should put in?
Thanks!
Cash in Austin, TX
72 F100, 390, AT, PS
Thanks!
Cash in Austin, TX
Cash,
Your instrument panel (IP) is one piece. Remove it. The speedo cable is a bear, take your time. The lights are inserted into a "lamp carrier". This plastic carrier twist into the IP. Be gentle, the IP housing is plastic and fragile. Replace your IP lamps with the exact bulb you pulled out. There still available and are the same bulb as the marker lamps of the truck.
Good Luck, Have Fun,
KingFisher
KingFisher
