Any Diesels or unique engines in 53-56 F-100's???
#31
That would be an interesting combo. I'd have to say that the Viper V-10 would probably be a better choice for a street rod though (as much as I hate to support Chrysler). Viper V-10, with matching 6-speed manual. That would be a serious grocery getter. Maybe a full tube chassis with 4 link rear, and Art Morrison IFS. A nice Strange 9" out back, with a killer set of M/T's. set it about 2" off the ground at the front bumper, and 4" at the rear. Dual 3.5" exhaust with some F/M 40 or 50 series mufflers. A 100 to 150 shot of spray. Maybe a couple of 250# concrete blocks in the rear corners for rear end weight, or a serious rear wing. Paint it all subdued colors, like a nice dark purple or blue, or black with body color bumpers and grille. Tintied windows, power everything. 4 whel disk brakes, 18" wheels up front, and 20's in the rear. Lots of stuff. That would be trick!!!!!!!!!!!!
#32
Looks like you've put a lot of thought into that. I like the way you think.
#33
#35
Originally Posted by AZAV8
wmjoe1953,
Lots of people like the Cummins better than the International-built Powerstroke. The Cummins six might be a little long for the early F-Series trucks. My F1 has only 39 inches between the well in the firewall and the back of the radiator. I had considered the Cummins, but I was trying to NOT have to cut sheetmetal especially the firewall. I like the existing footroom. The Powerstroke, being a V8 is two cylinders shorter and the wider width will still fit in the F1 compartment with space left over.
Why not consider a diesel for your fire truck? You could use the power for the extra equipment the fire truck has to haul. Are you trying to keep it original?
Phil
Phil
I'm contemplating trying to find room in my 59 Dodge D100 for the cummins...It would make for one mean truck!
Bobby
#36
bobbytnm,
That's a good idea; but, that's where the turbocharger intercooler and A/C condenser are going. To fit those two and the radiator in front of the engine, I'll probably end up fabricating a new support. That support also ties the whole front of the body together as the inner fender panels and front fender support brackets bolt to it as well. That U-shaped monster only bolts to the frame in the middle. That whole mounting will take quite a bit of thought, imagination and planning. But, that is what makes hot rodding fun, right?
Phil
Phil
#37
Phil,
I hear ya. I made my own radiator mount. I chose a radiator out of a mid 70's dodge truck as it had the inlets and outlets where I needed. I used some 3/16x3 flat bar and bent it to fit between the fenders. I punched some slotted holes to replicate the original fender mounting holes. I added some more flat bar perpindicular to the sides for strenght and as mounting flanges for the radiator. It all worked out pretty well.
My big Caddy engine makes tons of torque at low rpms (I think its 365 ft lbs at 2600rpm) and is pretty efficient if you can keep your foot out of it. I still plan on using my truck as a truck but I doubt I'll be pulling the family travel trailer down the highway with it (I can't squeeze 5 people into the cab)
Take lots of pics of your truck, it sounds like a cool project
Bobby
Bobby
54-F100
80
10-28-2016 01:32 PM
Matt1966
04-04-2013 12:37 PM
HEAVY100
13
12-30-2012 08:13 AM
edsf100
06-02-2011 11:57 AM
