AC Problem -99 Ford Ranger
Old May 30, 2006 | 11:12 PM
Hd410's Avatar
Hd410
Angry AC Problem -99 Ford Ranger
I have a strange odor coming from my AC ducts when the AC is on and the system is not getting cold. My mechanic says it's prob. freon leak in the condenser...is a big job? Can it be done on the drive way? How long?
Old May 30, 2006 | 11:34 PM
FTE Trigger's Avatar
FTE Trigger
Is it like a musty/mildew type smell or more like a compressed CO2/nitrog. smell (chemical)??
A/C fixes can get expensive fast. I would personally pay for the diagnostic work (provided that it is a shop/techs that know their stuff), then based upon what they find, ask yourself is it DIY friendly? Maybe even ask the tech.
A "U.V." check should be one of the test a shop would perform, I believe you can even buy the kits from an auto supply store. But the combination of the UV dye and the special glasses should be able to help pin point if any leaks are external or locate and residue dripping or oozing out of a component.
When ever I did a seal change or other "up-keep" tasks, I always had a shop- "vacuum" the remaining refrigerant out and instructed them to keep it on for at least a good 30-40 mins. Did my fix, then recharged the system myself.
Old May 31, 2006 | 11:02 AM
Hd410's Avatar
Hd410
A/C Problem
Not a musty/mildewy smell & CO doesn't smell & I don't know what nitrogen smells like...so...basically its just a very different smell & the A/C won't work. That's why I'm leaning toward a leak in the system?
Old May 31, 2006 | 01:23 PM
Piffery1's Avatar
Piffery1
You may have a combination of problems. 1. Heater core leaking a small amount of coolant producing the smell. 2. Refrigerant leak. If the A/C quit all of a sudden (i.e., big leak) then you might smell it. If A/C performance gradually declined then I doubt there would be enough to smell. 3. Could be stopped up drain causing mold in/around evaporator. My guess is antifreeze smell plus some other A/C problem. You might find a refrigerant leak with dye (especially the ones tha glow under UV light) if it's fairly large and in a good location. Better to check with an electronic leak detector. In any case you need to add enough refrigerant to cause the compressor to run.
Old Jun 1, 2006 | 09:24 AM
Hd410's Avatar
Hd410
No...not an anti-freeze smell, more like a Chemical, Nitrogen maybe. Someone suggested that a seal in the rear of the compressor???
Old Jun 1, 2006 | 01:50 PM
Piffery1's Avatar
Piffery1
Nitrogen is the largest component of air and has no smell. Refrigerant has very little, if any, at least to my old insensitive nose. Some refrigerant oils may have a slight odor but not much. I'd be supprised if you could smell something inside the cab that was due to a problem under the hood unless is was so major that the problem could easily be seen, smelled or otherwise detected immediately upon raising the hood (such as smoke, fuel vapors. etc.). I'd concentrate on fixing the A/C.first, then worry about the smell.
Vinford
Jun 6, 2015 09:20 AM
jerryparks
Jun 3, 2015 02:43 PM
mshargrave23
Sep 15, 2013 12:02 PM
g tinsley
Jul 19, 2013 08:01 AM
