Lean Pop or Backfire through carb issue.
I have a 73 F100 with a 360. I just put a four barrel iron manifold (65) on it and a 600 CFM holley with a 1 inch spacer for clearance issues. I have rejeted both lean and rich as well as adjusted the accelerator pump and the dam thing still backfires through the carb WHEN IT IS COLD. When the truck heats up it rarely does it. This happens when going from a stop and when I punch it at cruise. Hope someone has had this issue before too. If it helps the truck and myself live at 7200 feet and it has 9-11 inches of vaccum at idle with a 6.5" power valve.
i have the exact same problem with my 390 with a holley 4160 600CFM. i have blown out so many power valves trying to drive it to get it warmed up to tune it it aint even funny. and the one time i did the idle mixture screws dont do crap to the vaccuum. im pulling about 15.5" at idle. some times if i hit the gas going to take off it pops 2 or 3 times and then gets up and goes, also when its cold and im cruseing aroud and i hit the gas to go up a hill it will pop once or twice and go up it.
If your mixture screws don't change anything when trying to adjust them you either have a vacuum leak, or your main idle stop is already set too high. To properly adjust the idle you have to get below 1,000 rpm. After that the intermediate circuit begins to come in. Also recheck for any vacuum leaks.
Well while you're at it, recheck the timing, it'll affect vacuum readings too. My 390 idles down to 300-400 RPM, if you can't idle down that far, chances are good that there is a vacuum leak somewhere. Also, retorque your manifold bolts. There are a couple of holes in a intake that must either be used or plugged. Make sure that neither of them are sucking air.
Originally Posted by 76 F-150 390FE
yep the vaccuum modulator is fine and i plugged all the vaccuum ports accept the brake booster one when i took the vaccuum reading.
Also did you check your brake booster? If so, how did you check it?
Another thing I don't understand is how PCV works... it seems like PCV would cause a major vacuum leak...
If you didnt check your PB booster just pinch the line to it completly closed with vice grips. If your idle speed changes its leaking. Also if it seems to be low on fluid and you have no brake leaks underneath the truck its leaking. You can check the auto trans fluid and if its low and you have no tranny leaks the vacum modulator is bad.
52 F1 Stocker
39
03-26-2016 07:15 AM
irlarson
05-19-2015 06:43 PM
76BigBlock
30
09-14-2011 01:35 PM
77F250CUSTEXP
07-08-2011 11:47 AM
