Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Reload this Page >
Felt funny w/ vibrate at only take off ( its not shudder)
Old 05-24-2006, 03:23 PM
YOMAN
YOMAN is offline
YOMAN is starting off with a positive reputation.
My FX4 '04, replaced driveshaft, and clutch pack so its really help a lot and no shuder until few day ago..
Its hard to explain but i ll try..
Its strange feel on ONLY on take off with turning left or right its like my truck is dragging something in back for few seconds AFTER its been sitting for few hours or overnight then after about a mile or so its all gone. its like theres no oil in somewhere either rear end or steering itself.
I checked underenath and all look good to me.
Maybe i ll re check the fluid in rearend axle. I uses purple Royal Max gear.
ANy tips or where else to check?? Theres no CEL.
Thanks!
YOMAN!
Old 05-24-2006, 03:54 PM
92merc
92merc is offline
92merc is starting off with a positive reputation.
Check that parking brake. A few have mentioned the parking brake dragging. Maybe hold the release lever and move the brake lever a few times and pump it.
Old 05-24-2006, 04:39 PM
ranger88a
ranger88a is offline
ranger88a is starting off with a positive reputation.
Did you use limited slip differential lube?
Old 05-24-2006, 05:28 PM
kaerch
kaerch is offline
kaerch is starting off with a positive reputation.
Yep, Sounds Like It Needs Some Limited Slip Additive... Clutches Are Sticking Together Back There
Old 05-24-2006, 08:24 PM
YOMAN
YOMAN is offline
to add some info...driveshaft replaced last april 06 and clutch pack replaced about more than 13 months ago. its SAME fluid since i changed almost a year ago.
Royal Purple has a fiction Additive in it. i think its 80w-90 gear oil. this is what I put in my rear end- http://www.royalpurple.com/prodsa/mgeara.html
I double check my parking brake and its all good but i will do the brake pump etc.
Thanks!
YOMAN!
Old 05-24-2006, 09:27 PM
xtrm1stang
xtrm1stang is offline
xtrm1stang is starting off with a positive reputation.
try servicing the rear diff and adding Ford friction modifier!
Old 05-24-2006, 10:45 PM
plumbguy
plumbguy is offline
plumbguy is new and has a neutral reputation at this point.
Ring and pinion
Ford just replaced my ring and pinion on my 04 150. There was apparently a warranty issue with it. seems OK now. Kinda hated wasting that good amsoil fluid only to have to tear it down again. I went back with the ford fluid and modifier. Hope it remains trouble free.
Old 05-25-2006, 06:35 AM
96f150's Avatar
96f150
96f150 is offline
96f150 is starting off with a positive reputation.
Like xtrm1stang said, Drain it down and use the Ford Friction Modifier. These clutch packs are very picky, anything else, and they stick and chatter.
Rich
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
