CCV mod and warrenty
any of you gone in for warrenty with the ccv mod done and have had any hassels with the ford guys about it?? just wondeering cause i hate the oily boots, but got to get a little warrenty work done so i can wait until i get the work done then do the ccv mod, but i may have to go in for work at a later time.
Any engine modification could be an "excuse" for a dealer to deny warranty. As far as the CCV mod and engine seal leakage goes, an improper CCV mod installation that does not allow enough "free movement" of gases to the atmosphere or a negative pressure to the CCV will actually cause seals to begin seeping oil. This would be a valid reason for a dealer to deny warranty.
Your problem could be a seepage from a number of sources other than engine seals or possible a fuel leak that when mixed with the gunk on the engine, could appear as an oil leak. Only a very honest and reputable (rare and dying bread) dealer would point out the difference.
Originally Posted by aklim
That is why I keep onto the old pipe so I can switch back to the regular mode if I have warranty issues.
