BTS VB install
Old May 23, 2006 | 11:25 PM
Lushman's Avatar
Lushman
BTS VB install
I am planning on installing it finally this weekend and was wondering if there is anything special that I will need since a lot of the shops will be closed on Memorial Day around here? Any tips or tricks as it seems pretty straight forward?
Old May 23, 2006 | 11:43 PM
jtharvey's Avatar
jtharvey
It's pretty straight forward. The only special tool you might need is an inch-lb torque wrench for the actual bolts and nuts that hold the VB in.
Tips - there's a little screen filter above the VB that will need to come out before you put the plate in that Brian sends. Pull the filter, put up the plate, then put the little filter back in, and then the rest of the VB.
- I used the DI sonnax kit instructions as a photographic guide and to get the torque specs for the VB
- Have about 8 quarts of fluid on hand
- Suggested to use a new tranny filter. It's cheap insurance, and since you've already got the pan off and the filter pulled out....
- Re-use the stock trans pan gasket. The new ones that typically come with a new filter do not work well and will probably leak.
Old May 24, 2006 | 06:34 AM
ryaneverk2's Avatar
ryaneverk2
Guzzle92 has an excellent writeup with pics and tips and other good info on his site, here:
http://guzzle.rbmicro.com/bts.html
Old May 24, 2006 | 08:24 AM
jtharvey's Avatar
jtharvey
Well, I didn't know guzzle had a writeup about it, or I would have sent you there. His info is, as always, excellent and very helpful!!
Old May 24, 2006 | 08:37 PM
Lushman's Avatar
Lushman
I can't wait for this weekend!
Old May 24, 2006 | 08:52 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
don't know if it has been mentioned before, but the stock pan gasket can be reused, and the bolts get 10 foot pounds on them, nothing at all it seems.
Old May 24, 2006 | 10:32 PM
arninetyes's Avatar
arninetyes
Yup. 10 lb-ft doesn't seem like much. I noticed my pan gasket isn't leaking, but there is a bit of weepage collecting dirt. So, while I'm under the truck this weekend, am planning to re-torque them.
Of course the VB bolts are very little torque - even measured in inch-pounds.
