94 Explorer 4.0 Stalling Issue
Old May 23, 2006 | 04:11 PM
Yettie1's Avatar
Yettie1
I have searched through as much as possible here with no real luck.
I have a 94 Explorer 4.0
The truck starts right up, no problem.
After idling for between 1 minute to 2 1/2 minutes, it dies.
It doesn't shimmy and shake or anything at all like that, JUST STOPS on a dime.
I replaced the IAC, still doing the same thing.
I've checked all vacuum lines.
While trying to figure this out the other day, it started and ran perfect for about 9 minutes, so, I got in to go for a ride, pulled up to the house, shut it off, went inside, came back out and drove about 50 feet and died.
It will start back up fine after a few minutes, then after 1-3 minutes, STOPS DEAD.
Any help appreciated greatly.
Old May 24, 2006 | 10:47 AM
mrshorty's Avatar
mrshorty
I think the first thing I would do would be to pull codes from the computer to see if the computer can see the problem. You can pull codes with nothing more than a paper clip (there are instructions all over the internet, or in any self-respecting repair manual).
When it stalls, is it losing spark or fuel?
Old May 24, 2006 | 12:31 PM
87 XLT's Avatar
87 XLT
Like mrshorty sez, you need to figure out whats missing spark or fuel
When it stalls & you turn the key off & back on, do you hear the fuel pump run for 2 seconds?
Easiest way to check for spark is to connect your timing light to any plug wire and crank it.
Does the light flash?
Old May 24, 2006 | 06:26 PM
Yettie1's Avatar
Yettie1
I ran some codes on it and most of them led to the MAF Sensor, so, I disconnected it and the truck ran good, i took it for a 6 mile ride without hesitation or stalling.
The MAF Sensor looked pretty new, so, I didn't suspect it.
I'm going to buy a new one and try that since most every code was leading to that.
Yes, the fuel pump primes when you turn the key off and on.
Thanks for your input guys, REALLY appreciated.
Old May 25, 2006 | 02:00 PM
Joe-1957's Avatar
Joe-1957
Smile Simple Fix
All you have to do is replace a circuit braker the sits on the right side wheel well in the engine compartment. I had the same problem. As soon as that circuit breaker heats up it goes to the open position and kills the engine. I had the dealer do everything possible to my Explorer, and all it took was reading the owners manual.
Old May 25, 2006 | 04:29 PM
Yettie1's Avatar
Yettie1
Thanks
Thanks Jim! I will go check that out right now.
MUCH APPRECIATED!
Old May 27, 2006 | 08:37 PM
spaz218's Avatar
spaz218
Try simple
What about fuel relay? fuel filter...or even fuel pump?
Maybe fuel reset?
Old May 27, 2006 | 08:39 PM
spaz218's Avatar
spaz218
if you replaced the air control valve make sure the pipes are clean
Old May 28, 2006 | 12:09 AM
Yettie1's Avatar
Yettie1
I disconnected the MAF sensor and now it runs great, no problems at all.
Old Jun 2, 2006 | 10:53 PM
Calica's Avatar
Calica
I'm wondering if this is the same problem I have with my 93 Explorer. I go to start it and it bogs as if it is wanting to start, but back fires and will not idle. If you shut it off or it dies before doing so, you go to crank it up again and it starts fine and runs fine. it does it every so often. Just the other day it did it to the point where I tried for about ten minutes before it cranked up fine again. Any advice on this particular issue would be greatly appreciated.
