Trailer wiring
Trailer wiring
Working on a 2002 Super Duty with towing package. I have run the 7 wire plug from the fifth wheel hitch down through the bed to the 7 pin connector on the rear of the truck.
Is there a nice little y connector or pigtail available for this connection are am I going to have to splice into the truck wiring harness?
Thanks
MT
Thanks
MT
I haven't seen a Y splitter. You could make your own but I wouldn't chance it. Same with using a trailer connector pigtail. Since towing connectors always have problems with corrosion and making good contacts your #1 best bet is to splice in and solder and waterproof the connections.
