Offroad & 4x4
Chevy NP 208
Old 05-25-2006, 05:43 PM
Dustin_86's Avatar
Dustin_86
Dustin_86 is offline
Question Chevy NP 208
I want to take a chevy NP 208 and have a shorter collar drive shaft built to divorce it to my NP 435. I know I will have to drill the cross member holes for the case and have a d- shaft built but what else. The donor is a 84 1/2 ton chevy 305 auto. my truck 78 f250 2wd NP 435
Dustin
Old 05-25-2006, 05:49 PM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
Its Comin Right for us!
Received 1,428 Likes on 933 Posts
you putting a chevy front axle under your truck?
Old 05-25-2006, 07:03 PM
Dustin_86's Avatar
Dustin_86
T- cas, not axle
Old 05-25-2006, 07:31 PM
chrono4's Avatar
chrono4
chrono4 is offline
different offset, chebys diff is on pass side, ford is driver
Old 05-25-2006, 07:33 PM
Dustin_86's Avatar
Dustin_86
so it will not mate to a 2wd NP 435 via a biult drive shaft
Old 05-25-2006, 07:35 PM
chrono4's Avatar
chrono4
chrono4 is offline
oh it will, but your front drive line will be on the wrong side. just got divorced 205 or d 20
Old 05-26-2006, 12:50 AM
KubotaOrange76
thats what im getting at, your front drive output will be on the passenger side versus ford's driver side...you for a 4x4 front axle you will need a chevy or dodge front axle
Old 05-26-2006, 01:01 AM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
it oculd work with enough lift and CV's on both ends of your driveshaft, but thats a lot of work for trying to run chebby CRAP! just get a ford 208 and stay true!
-cutts-
Old 06-07-2006, 05:32 PM
Dustin_86's Avatar
Dustin_86
my truck is a 2wd. So YEs it will work??Maybe?
Old 06-07-2006, 05:53 PM
Jmudder79's Avatar
Jmudder79
Jmudder79 is offline
It won't work unless you put in a front axle with a passenger side output. Ford front axles have drivers side outputs. I would stick with Ford parts myself. Don't want to contaminate a good truck.
Old 06-07-2006, 06:09 PM
BroncoRoadKill's Avatar
BroncoRoadKill
BroncoRoadKill is offline
Maybe I can help.
Yes, the t-case will bolt up.
But, in the end the output is on the pass. side.
You can not clock it and run it upside down so that the output is on the drivers side.
If you bolt that t-case up, the driveshaft will not bolt up.
You need a ford t-case or a GM or dodge front axle.
Old 06-07-2006, 06:37 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
You guys aren't getting what he is saying, his truck is 2wd, he doesn't have a front drive axle just wants the low range unless i am reading him all wrong.
Old 06-08-2006, 12:00 PM
Dustin_86's Avatar
Dustin_86
thanks, moster
Yes you read me right!2wd/low range... BINGO
Old 06-08-2006, 04:43 PM
chrono4's Avatar
chrono4
chrono4 is offline
well if thats what u want, put it in there. itll work with a diffrent driveshaft.
Old 06-08-2006, 10:49 PM
RubberDuck's Avatar
RubberDuck
RubberDuck is offline
US Gear underdrive. I believe Gear Vendors makes one too. I have GV overdrive and love it. Spendy, but cool.
Quick Reply: Chevy NP 208
