Quick Questions
Old May 15, 2006 | 08:48 AM
bigskenney's Avatar
bigskenney
Quick Questions
I recently started looking around for an older Ford an found a F350 4x4 with a 400 and a 4 speed in an add. The guy says it's a 78 but I'm not sure because the pic. of the truck shows rectangle headlights like my 79 Bronco and I thought that the 78's had round headlight. But either way I am probably going to go take a look at it this evening or tommorow. I just wanted to find out from you guys what I really need to look form and check out when I go down to look at it. Thanks
Old May 15, 2006 | 08:57 AM
tjc transport's Avatar
tjc transport
i ain't rite
mid year 78 the F series changed from round to square headlights.
Old May 15, 2006 | 09:03 AM
78workhorse's Avatar
78workhorse
I've Had 3 78's. 2 Had Squares 1 Had Rounds. Just Depends What Time Af Year They Were Built. They Both Looked Good To Me.
Old May 15, 2006 | 10:11 AM
73Custom's Avatar
73Custom
Actually the date doesn't matter. The base model is a Custom - Customs had round lights. The higher models - Ranger, XLT, Lariat - all had rectangle lights.
They are good trucks, make sure it runs/drives good. They get rust in the usual places - floor boards and over rear wheels - depending on how it was cared for. A F350 4x4 is a tough solid truck, it will take a lot of abuse.
Marty
Old May 15, 2006 | 10:46 AM
77300i6's Avatar
77300i6
A true F350 4x4 will have dana 60's f & r. F350 4x4's are not too common. VIN should have an 'H' in it to denote a factory 400.
Old May 15, 2006 | 01:26 PM
Mil1ion's Avatar
Mil1ion
No Trucks had SQUARE headlights.
Please.... they are Not square, they are rectangular.
1978 Trim lines above Custom got Rectangular hedlights
That means 1978 Ranger Explorer, Ranger XLT, Ranger Lariat have Rectangular headlights.
In 1979, all trim lines received Rectangular headlights
Engine code = 4th digit of Vin#
Engine Code H for F series is for 351M
Code S for F series is for 400.
Code H in E series is for 351W.
Old May 15, 2006 | 01:37 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Theres no such thing as a 78 F-350 4x4. 79 was the first year for those. Also a rectangle is a square but a square is not a rectangle. Basic geometry.
Old May 15, 2006 | 01:49 PM
Mil1ion's Avatar
Mil1ion
They Better change the OVAL office to the ROUND office in the white house.
That way they can finally ask that question:
Q: How do you drive the president of the USA crazy ?
A: Put him in a round room and tell him to pee in the corner
Old May 15, 2006 | 03:03 PM
tjc transport
i ain't rite
Originally Posted by Mil1ion
No Trucks had SQUARE headlights. they are rectangular.
i knew that dennis, i was just to lazy to type out rectangular.
Old May 15, 2006 | 05:21 PM
alcan60283's Avatar
alcan60283
Oh yeah, well my 78 F-150 Ranger XLT came with round lights, not rectangle ones ! so theres your cog in the machine. It really depends on when it was ordered/built. Because mine was built in 7/77 before the rectangle lights were available, so they slapped round ones on instead. I then put rectangle ones on later. I think the 78 models that were built in 78 all had the rectangle lights on the Ranger/Ranger XLT etc etc etc
Old May 15, 2006 | 05:45 PM
FordPickup460's Avatar
FordPickup460
You got it backwards
Old May 15, 2006 | 05:48 PM
Mil1ion's Avatar
Mil1ion
Then that truck is a 1977.
The starting production month for 1978's was August 1977
Old May 17, 2006 | 05:26 AM
bigskenney's Avatar
bigskenney
I didn't realize headlights were such a hot topic. I still haven't gone down to look at the truck. But since it is obvious that I can't use them to tell what year the truck is and someone said there was no 4x4 F350 until 79, how can I tell if it is a 79 and the guy got the year wrong or ifit is a F350 clone?
Old May 17, 2006 | 07:06 AM
cujo8's Avatar
cujo8
The 1977 F150 I recently purchased has a 1978 front clip on it when I bought it. The best way to tell the year is to check out the vin plate on the truck.
Jim
Old May 17, 2006 | 07:24 AM
Torque1st's Avatar
Torque1st
Posting Legend
To determine what the truck is check the VIN on the door AND the frame.
In model years 77.5 thru 1978 an F series with custom trim came with round headlights. Some of them may have even been fitted with "rectangular" headlights towards the end of the 78 model year due to parts availability. Model year 77.5+'s were considered to be ~78's and were called a mid year introduction. This still happens today when design and production schedules slip. Unfortunately due to production schedules and parts availability some early production "78" Ranger & R-XLT's etc were made with earlier model parts which in some cases included round lights. There were major changes in midyear 1977 in body styles, suspension, and powertrain. Many replacement parts are called out by sequential VIN numbers in 7 and 78 because of running changes. Sometimes the sequential numbers are not even right due to special orders and fleet vehicles. We should have a 73-77.5 and a 77.5-79 forum but there are also many similarities and the line is blurred so 73-79's get lumped together.
