1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250: A Driveline Clunk Or Bump When Starting From A Stop
  #31
Old 02-11-2009, 05:31 PM
afonda's Avatar
afonda
afonda is offline
bump to the top.
  #32
Old 09-17-2009, 12:44 AM
surfj9009's Avatar
surfj9009
surfj9009 is offline
Originally Posted by Krewat
The only time the spline "clunk" is heard is when starting from a dead stop.
A clunk "at speed" could be splines, or most probably u-joints or hanger bearing. I'd check those first!
I am glad to see this posted. My vehicle clunks when accelerating from a stop, AND at cruising speed. I can hear it everytime I am driving along and let my foot of the gas pedal to coast. (manual tranny)
I guess i have a few things to look into.
bump to the top.........
  #33
Old 09-30-2018, 06:31 PM
CousinJordo's Avatar
CousinJordo
CousinJordo is offline
I fully expect to get chirped for bumping a decade old thread, but just wanted to confirm that the slip yoke service corrected the “bump-thump” when accelerating from a stop for me as well. I performed the service today in about 15 minutes.
http://www.frontiernet.net/~jcray/04...50SlipYoke.pdf
Supplies used:
12 mm shallow socket
Red and Tacky grease (I use this for everything)
Pliers
zip tie
A little elbow grease!
I tried to drop the front U-joint first, but I couldn’t break it loose. Instead I indexed the position and dropped the rear joint of the driveshaft from the rear diff. MAKE SURE YOU CHOCK YOUR TIRES. Removed the boot clamp, gave the driveshaft a tap with a mallet and it slid free without any trouble.
I greased, reainstalled without thread locker on the 4 driveshaft bolts. Should I have used it? I tightened the snot out of them, but I’m not certain if they had it on there to begin with.
Anyway, just wanted to echo that this was the solution for mine!
78_f800crewcab4x4
08-24-2022 03:28 PM
scottjima
229
01-15-2018 09:33 PM
eberlestock
6.2L V8
09-05-2017 09:38 AM
PokerMunkee
06-02-2016 06:45 PM
HunerdProof1371
11-15-2012 01:01 AM
Quick Reply: F250: A Driveline Clunk Or Bump When Starting From A Stop
