Boost pressure ?
Old May 13, 2006 | 08:54 PM
XxfirmanxX's Avatar
XxfirmanxX
Boost pressure ?
Just wondering if 7 Lbs of boost is normal when your running 55mph. But then the turbo spools and I hit 14 lbs then back to 7 lbs. thanks for any help
Old May 13, 2006 | 09:00 PM
vloney's Avatar
vloney
did you just have a reflash? There is a possibility that its trying to "relearn" turbo function.
Old May 13, 2006 | 11:29 PM
tedbiv's Avatar
tedbiv
Talking seems normal
I have a new 06 6.0 250 4x4. At 55 i'm running about 1750rpm with maybe 7-10lbs boost depending on grade. I'll go to 20-25 if i'm on a steep grade in low gear, or giveing it the gas. I wouldn't worry about it. 7-10 is well within the "normal" range.
tedbiv
Old May 14, 2006 | 08:58 AM
XxfirmanxX's Avatar
XxfirmanxX
Truck was reflashed about 3 weeks ago but everything seems to be working good just wanted to see if everyone else has the same boost pressure and it sounds like they do. Thanks for the help
