1978 - 1996 Big Bronco
Cardan Joint
Old May 11, 2006 | 08:49 AM
johnarahill's Avatar
johnarahill
Cardan Joint
Is there anything special I need to know about that special joint at the top of the rear drive shaft? I need to replace those u'joints up there, and if there's somthing unique about the job I want to know before I disable my truck and get stuck halfway through it.
Old May 11, 2006 | 11:17 AM
Encho's Avatar
Encho
The Southernmost Mod
Well, be extremely carefull with the new security pins of the ones you´ll mount, as you can take them out again once installed, and try not to be so harsh on the new joint, also watch if it has greasers or if it´s a sealed one (the ones with grasers need to be lubricated every now and then).
If you have any real emergency if the meantime of the repair, just dismount the Cardan, put the truck on 4WD and roll it that way (i don´t recomend doing this, but it would take you home if you where in a hurry).
Old May 11, 2006 | 11:59 AM
alxsnmr's Avatar
alxsnmr
Strangely I had the same question about the same joint last week. Is there any specific steps to taking it apart. That is, the order to start in? Better yet is there any photographic step by step instructions available in print or the web?
Old May 11, 2006 | 02:35 PM
jem270's Avatar
jem270
Look under "Technical part 1" then "driveline" and look for "cardan".
I just found this site recently. Lots of good stuff.
http://mywebpages.comcast.net/miesk5//
1988 EB Bronco - 302 - AOD - 3.55 Lim Slip 8.8- Manual Hubs and Transfer Case - BFG 32/11.5 AT - 209,000 miles
Old May 11, 2006 | 05:05 PM
johnarahill
Who knows what kind of socket it is that I'll need to get the bolts out of the yoke on the back of the transfer case? ?
Old May 11, 2006 | 07:09 PM
alxsnmr's Avatar
alxsnmr
I think you can use a 12 point socket to turn the bolts loose.
Old May 11, 2006 | 11:55 PM
greystreak92's Avatar
greystreak92
yep. 12pt. 13MM and the centering ball and spring are the components that you need to take care to get in there properly.
Old May 12, 2006 | 07:22 AM
johnarahill
Thanks Greystreak.
Old May 12, 2006 | 12:24 PM
andym's Avatar
andym
I just did this, and there are a couple tips I wish I'd had.
Be really careful when you install the u-joints. I replaced mine with spicer greasable ones from JBG, and once you press the u-joint in, you can't get them back out. Then I realized that I put it in the wrong way, and I wasn't going to be able to get to the fitting. When these dry out, it goes to a shop, because I won't be able to get them out.
When you buy the u-joints, buy the ball repair kit too. I bought mine from JBG as well, and they had it for $14. Napa wanted $40, and I had it torn apart when I realized I needed one. So the Bronco sat for a week because I wasn't paying Napa prices for cheap chinese junk.
So buy the ball repair kit, and be real careful about the orientation of the u-joints.
