Rear Main Seal Leak on 302.
Old 08-11-2006, 01:16 PM
90efi's Avatar
90efi
90efi is offline
My 78 302 engine has always had a slight leak but now it is getting worse than ever. I know these seals are noted to go on Fords. So what should I be prepared for if I decide to fix this leak. Does the tranny or engine have to come out?
Thanks for suggestions.
Old 08-11-2006, 02:05 PM
P51D Mustang's Avatar
P51D Mustang
P51D Mustang is offline
Yeah, you need the fly wheel or flex plate out of the way. You can then pry out the old seal and then tap in a new one. I always put a film of silicone around the outside, more for lubication than anything, and I also put a bead of grease around the inside of the seal were it contacts the crank, so it doesnt get damaged or burnt on start up.
Old 08-12-2006, 06:31 PM
90efi's Avatar
90efi
90efi is offline
My next question is does any of the of the shelf stop oil leak bottles of oil work? Maybe to help swell the seal?
