89 f150 speedometer prob
Old May 7, 2006 | 10:33 PM
jprichard's Avatar
jprichard
About 3 weeks ago my speedometer stopped registering, I found the problem to be the driven gear. The teeth were worn down and it was not meshing with the gears in the transmission. I figured that this was just normal wear. I replaced the driven gear and voila the speedo worked again. It worked for about a week and then died again. I have not checked to see if the driven gear is the culprit again. My question, is there something in the transmission that could be destroying the gear? Thanx in avance for any help or advice.
Old May 8, 2006 | 05:40 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
…..See you on the boards.
