Are all Fords the same?
Old 04-22-2006, 09:17 AM
jefftino's Avatar
jefftino
jefftino is offline
I am interested in purchasing a used diesel van for around $10K. I have not seen too many. I'd like to run biodiesel. Is there any years or types of engines to avoid (6.0 vs 7.3, engine management issues?, etc.) Thanks
Jeff
Old 04-22-2006, 10:48 AM
bentring's Avatar
bentring
bentring is offline
As long as the biodiesel is processed correctly, then, according to everything I've read, you shouldn't have any worries.
Old 04-26-2006, 09:15 AM
AndysFords's Avatar
AndysFords
AndysFords is offline
Although they all run biodiesel, I would personally stay with the 7.3.
Old 04-26-2006, 11:47 AM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
6.0 engine fords stand is not over 5% biodiesel - - - on the 7.3 on an idi engine I've used 20% bio with not problem.
Old 04-26-2006, 12:31 PM
Tx_Atty's Avatar
Tx_Atty
Tx_Atty is offline
the 6.0 was a problematic motor in the range from 2003 through 2004 but has improved since. Ford says nothing over 5% in any of its diesels but that is just their way of dodging any responsibility. I run close to 100% in my 7.3 with no issues and am getting closer to 100% each time I fill. Do a net search for Steve Baz. He has a web site that gives tips on buying a used Powerstroke on one of his pages.
Old 04-26-2006, 02:12 PM
jefftino's Avatar
jefftino
jefftino is offline
Whats the diff with powerstroke and 7.3 or are they the same?
Old 04-26-2006, 02:17 PM
Tx_Atty's Avatar
Tx_Atty
Tx_Atty is offline
same, first Powerstroke was the 7.3 but is now a 6.0.
Old 05-06-2006, 11:09 PM
parkland's Avatar
parkland
parkland is offline
To be more specific for somebody who doesnt know;
the 6.9 "international" (pre 1990) non-turbo IDI Diesel , around 160HP
the 7.3 "international" (1988?-1994) non-turbo IDI Diesel ,around 170HP depending on year
the 7.3 "powerstroke" (1994-2003) turbo DI Diesel ,around 250HP depending on year
the 6.0 "powerstroke" (2003-2007) turbo DI Diesel ,325 HP
Old 05-07-2006, 05:43 AM
jimkidd's Avatar
jimkidd
jimkidd is offline
Jeff
From what I've read jeff, if you get a Powerstroke you should be ok. Ford switch over in '94 (94.5 model) and from what I can tell that's about the time they stopped using rubber in the engine. I like the '96 & 97 years. But I'm an OBS guy. I would stay away from the 6.0L for like 03 & 04.
jimbo
