Change pads now soft brake pedal
allright, what the.....
I put on new pads on my 04 EB with 30k miles, didnt open the brake lines, just pushed the cylinders back on the calipers to fit in new pads, everything went back well but now the brake pedal is soft...
I have done this a million times in other vehicles...whats going on??
I didnt open up the system so I doubt air got in, I have never had to bleed brakes before unless I open up the lines.....
Originally Posted by Big Craig
did you take off the master cylinder cap for the fluid to escape? if yes is it low now? if not check into pricing for a antilock valve and or master cylinder replacement.
Kiosk, it is perfectly ok on ABS vehicles to back press your calipers so you do not have to bleed the system when done, however you HAVE to remove the master cylinder cap to allow the fluid being pushed back somewhere to go.
If you are lucky maybe you can try to bleed the brakes in the pattern the mtx manual calls for, there is a specific pattern to do this, do not just do the fronts then rears or visa versa like with old cars you have to do a certain wheel at a time to avoid getting air in the ABS module.
I do not have my manual here with me, if you need the pattern get a chiltons or email me tomoro for some help.
That happened to me when I changed my pads, I did mine around 30k as well. I read somewhere that the pads need to break in with the rotors, since I didn't turn or replace the rotors (they were fine). I went on back roads and rode the brakes for a few hundred feet, then let them cool, did it again, and let them cool. Along with pumping the brakes at a stop, and doing a few hard stops. Now my brakes work just like new.
I did remove the reservoir cap, and it did overflow, but I put rags around to catch the fluid.
Sorry I said I didnt remove the reservoir cap, which I didnt, but I did loosen it up so air could scape.
jiujitsustudent
05-30-2017 11:46 AM
Mdc9966
01-19-2017 10:13 AM
