DIY Coolant Tank for Machinery
After pricing coolant systems for my lathe, I simply don't have several hundred dollars to blow on such a thing. Also, I wanted to include my floor standing Delta drill press in the cooling system, so my hole saws last longer. I cut enough thick-wall tubing and header plates that I go through hole saws very quickly, even turning them at 150 RPM. Cooling/cutting fluid is the answer, so I decided to build a simple coolant tank, pumping system with valves so I can select between the drill press and the old Clausing lathe I recently acquired.
Here is the insides:
http://frederic.midimonkey.com/yard/...t/IM001762.JPG
And the outsides:
http://frederic.midimonkey.com/yard/...t/IM001763.JPG
And the entire buildup text with pictures:
http://frederic.midimonkey.com/yard-lathe-coolant.html
And the outsides:
Frederic you build the neatest stuff!
Does your drill press table have the collection pans and grooves?
Chore girl copper pads make decent filters cheap for the big stuff.
Your "coolant" will stay warm in that "cooler" so watch for bacterial growth.
I also have to acquire (or make) the rest of the plumbing to drill press and lathe as well as install nozzles. I was hunting through google trying to find cheap magnetic mount coolant nozzles for both machines.
