Gauges for 2006 F350
I asked the Ford parts manager about wanting to get gauges for my truck. I am interested in EGT, transmission and turbo gauges. He said that the new trucks do not need them since everything is monitored by the computer. I am not sure I want to rely on the truck's computer only. I will be towing a 14,200 lb 5th wheel. What other gauges do you think I might need, someone mentioned air - how does that work? Thank you for your help in this.
on
Welcome to the 6.0 Forum here at FTE ..gregk. When you get a chance check out our 6.0 Tech Folder.
https://www.ford-trucks.com/forums/s...d.php?t=303583
I just added the oil temp, trans oil temp and the EGT gauges on a piller pod. Used the new Stewart Warner Cameleon system. Watching those lamps change to any color you want is really kewl!!
I tow a 30' fiver, so that's why I wanted those 3 gauges. Boost is boost and I don't have a programer so didn't think I needed that. I DO wnat to keep and eye on those other two temps tho. The Ford tranny temp gauge is a joke.....and I know the oil pressure is up, but it's also nice to know the temp of that oil.
Originally Posted by bell430pilot
Tranmission temp and turbo boost is covered by the instrument cluster on my 06 F350. Exhaust gas temp is NOT. If you are running stock, the computer "should" prevent excessive EGTs (over 1250 * F). If you have chip or tuner you may exceed save EGTs. Michael
The turbo boost gauge has been shown to be fairly inaccurate, but at least it's a real gauge.
And, I don't believe there's any sort of pyrometer in the factory installation, so the computer doesn't know what the EGTs are. Ford programmed the computer to not run hot enough to allow too-hot EGTs, but there have been reports from stock trucks with gauges that the EGTs climbed up into the unsafe zone when pulling big trailers up big hills.
Trans temp, boost, and pyro/EGT are quite useful gauges. That being said, I've not yet installed any in my truck.
I used the stock boost gauge. On my A-pillar I put volts, EGT, tranny (again do to the factory gauge) and oil temp. I can tell you when loaded up the tranny and oil get hot. I would get the gauges with that load you're pulling. $500 is good protection against a serious failure. You can't fix anything on these trucks engines or trannies for <$1000. Even though you still have a warranty, dealing with ford (who doesn't seem to understand that Superduty downtime costs people money) is a pain.
Cameleon By Stewart Warner
If you want to see how this lighting system looks, go here to see the video I took. http://www.discountpowerparts.com/Online_Store/Stewart_Warner/STEWART_WARNER_Main_Page.html
Now that, I'd buy. Analog gauges with digital smarts. There's a market...
That would be neat! I remember my Dad's old '48 Plymouth. It had a speedometer that did that. It started in green then changed towards red the faster you went. I used to see how red I could make it get......it stayed red from about 65 and as fast as we could pedal it.....90-95? Downhill...with a tailwind.
Even better, how about a head-up display for the gauges?
78fordbeast
10-04-2014 09:06 PM
carwash
10-05-2005 07:52 PM
