Sponsored by: Kumho
firewall boot for steering shaft.
Old May 1, 2006 | 04:23 PM
Mike B.'s Avatar
Mike B.
I have a 2006 F-250 that makes an annoying sqeek comming from this boot. The dealer just squirts lube down here to help the problem but the noise is still there. How can I get some lubrication in there properly. How does this come apart? Does any one have a fix for this?
Old May 20, 2006 | 10:24 PM
amish77's Avatar
amish77
I'd disconnect the steering shaft from the firewall, then slide it out of the boot, clean it up really good, and use a heavy grease on the boot and the shaft. Put it all back together and you aughta be squeek free.
Old May 21, 2006 | 08:28 AM
rebocardo's Avatar
rebocardo
I have never taken a 2006 apart since I no longer work at a dealership. But, on most Fords it is more then just boot. There is usually a piece of foam and a seal inside that boot, which is probably causing the squeaking. You have a brand new vehicle, it is not 1940, have them fix it properly and do not accept the squirting the grease in as a solution because it is not one, imo.
As for the boot, it usually requires pulling the steering column or shaft on a Ford becaue it is one piece.
TexasGuy001
Jan 16, 2017 07:02 PM
Donebrokeit
Modular V10 (6.8l)
Apr 28, 2016 07:32 AM
fnx4wheeler
18
Feb 20, 2010 10:20 AM
Munch
1997 - 2003 F150
Jun 8, 2009 04:02 PM
txaggie96
Sep 3, 2008 06:13 PM
