T98 with PTO
T98 with PTO
Just curious if there is any interest in a borg Warner T98 trans with the factory PTO output gear box attached to it. It is out of a 1954 F350 that had a dump bed.
I have a non PTO T98 already; don’t need a PTO on a stake truck I am doing, and debating which one to keep/use/sell.
if it isn’t worth much I might toss in the PTO unit Incase I ever wanted to use it in some fashion.
t98 pto
PM Me if so.
Thanks!
Ian c.
your correct. The only way for the PTO to spin backwards is if they ever made one with a "counter gear". It would need 3 gears in it. 1 gear used for forward and 2 gears used for backwards. Next is, if they make a pump that allows reverse rotation?
Every PTO setup of this age I have ever worked on has been 1 direction only, with a gravity return to the oil reservoir.
Greg,
your correct. The only way for the PTO to spin backwards is if they ever made one with a "counter gear". It would need 3 gears in it. 1 gear used for forward and 2 gears used for backwards. Next is, if they make a pump that allows reverse rotation.
Is this available?
[/QUOTE]
sorry sold it about 6 months ago.
tnfarmer67
09-05-2010 02:56 PM
46autocar
06-08-2010 11:42 PM
