Metals and Bio-d
Metals and Bio-d
I know that you aren't supposed to use copper or alluminum with WVO, but what about bio-d? Are the restrictions that same? What are some of the other guys using? is it all mild steel piping? If so, what size/gauge and how are you setting up your coils in your tanks? I have a slip tank for this set up and want to get it firgured out before I start buying, cutting or welding.
Thanks
Thanks
Thanks
Thanks
FABMANDELUX.
Originally Posted by bentring
What temps are you referring to fabmandelux? Also, please check your private messages fabmandelux.
So far I have had no problems with B-80 down to 12 deg F. In the last 2 years that is the lowest temps we've had. B-50 should be good to 0 deg according to the cold tests i've done.
The answer to your PM is yes.
FABMANDELUX.
