Mixing Oil 50/50
When I drove long-haul (early 1970's-early 1980's) this was a common thing...it was due to the incredibly high cost of synthetic when it was first available (and the need to maximize mpg's). In fact, one of the trucker magazines (Road King?) did a test of mixing synthetics with dino oil at different percentages and then running mpg tests. If I am not mistaken, the mpg effect was the same at 10% synthetic/90% dino as it was at 100% synthetic.
You might want to check out bobistheoilguy website...
on
as a mechanic i have used the rule of thumb that mixing unlike oils and coolant is not a good idea. different chemical makeups you have no way to know if they will react with each other until it has hurt your engine. but i have not heard of any proof that may happen but i am not willing to take the chance.
Originally Posted by hott-rodd
For only $35 extra the synthenic gives you get better fuel milage, the longer change interval, and a smother running engine. Spead the cost over the time it's well worth it.
Tomorrow I'm measuring for the length of hose I need and am ordering an oil bypass filter and 5-gallons of GP IV synthetic.
Far fewer oil changes, less wear, and (hopefully measurably) better fuel economy.
