Whats the Difference between code E and X 4.0 engines.
I have a 99 OHC 4.0 and bought the code E plugs. The only difference between the two plugs is the heat range.
Any ideas?
BTW the only plugs I could find listed were Bosch Platinum.
2) Not sure what the OHC motor code is but the "push rod" 4.0 is definitely a "X" motor.
Heat ratings are just a longer insulator nose for higher ratings. If you are a stock application, just go with Ford's recomendation.
They have;
NGK
NGK iridium,,,,,,,they have these but $18/2 plugs is too pricey
Champion
AC delco
Bosch
Bosch 2
Bosch 4
Motomaster V-groove(canadian tire brand)
Their book only listed #'s for the iridiums and Bosch plugs for some reason
