How Low From Jag XJ6 IFS?
I am seriously thinking about using a Jag front suspension. I have a 55' F100, and I was wondering how much using a stock XJ6 subframe will lower my truck. Also does anyone know how hard/pricey it is to lower it more if I need to? I want the center of my fender to be about 24" from the ground, and have come to realize that isnt practical with the straight axle.
Thanks
-Mike-
Thanks
-Mike-
Hey there 49,
I have read all the info already posted or linked to the install that I could find. There was a great amount of useful info, and am confident I can do the swap. The couple things I couldnt find were the things mentioned above. I still need to know atleast about how much it will drop, and if there is any way I can drop it more. And most of the pictures I saw didnt have the front fenders on the truck so it was hard for me to visualize =(
Thanks
-Mike-
Thanks
-Mike-
Originally Posted by turborscapri1984
Hey there 49,
Thanks
-Mike-
Thanks
-Mike-
MIke, the center of the axle is about 2" below the mounting points on the subframe, including rubber mounts, with no weight on it. Willards estimate of a 2' drop installed would put the axle even with the mounting points. Half of your front tire heightwill give you your axle height. Check the website that willard posted, good info there.
Thanks for your measurements. I want mine dropped like yours B/B, your truck is pretty much like this :
I cant afford a MII and dont feel as comfortable istalling that on my truck. But I did find another truck with a MII already installed, and I might purchase it.
Either way, I like the Jag setup better.
Thanks Guys
-Mike-
Thanks Guys
-Mike-
ajatruck
02-02-2015 06:56 PM
jamieson48
01-22-2012 01:32 PM
axman
01-04-2007 01:29 PM
