1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Looking for Expedition Tire TSB
Old 04-25-2006, 10:36 PM
kkester
kkester is offline
kkester is starting off with a positive reputation.
I've been trying to find one of the TSB's related to 2005 Expedition tire problems, but it doesn't seem to be listed on Alldata or Infotraxx. On the NTSB web site, it is described as follows:
Bulletin # 18228
Sequence # 10010737
Date 20041001
Component 190000 Tires
Tire feathering at low mileage.
Does anyone have access to the complete TSB? I'm in the process of putting together a submission to the Dispute Settlement Board and am in need of as much background information as possible.
Kent Kester
Old 04-26-2006, 11:29 AM
mtnman64
mtnman64 is offline
mtnman64 is starting off with a positive reputation.
Go here (link from this site) and enter your model info to find the TSB's
https://www.ford-trucks.com/tsb/tsb.php/m-FORD
Old 04-26-2006, 11:38 AM
kkester
kkester is offline
I've already been there. Unfortunately, it only lists a very brief summary of the TSB--not the details.
Old 04-26-2006, 11:57 AM
026TB4U
026TB4U is offline
026TB4U is starting off with a positive reputation.
I'm in the same boat and would also like the info, so hopefully someone can post it.
Old 04-26-2006, 07:48 PM
garyle
garyle is offline
garyle is starting off with a positive reputation.
I had the same problem and could not find a TSB. The condition is "Steering Nibble" and Ford is well aware of it. A lot of speculation on what causes it but it is NOT acceptable. I believe it is caused by 1-2 out of every 10 Continental tires being bad, along with a very sensitive rack and pinion steering unit, makes the steering wheel shimmy when 1 of the tires "bad spots" gets out of sequence. That is why it goes away from time to time.
I brought a large number of posts to the dealer and basically told them how to fix it, and... I was not going to bring back the loaner until it was right because it is a SAFETY ISSUE!!!!
The good news is that my 05EB is now smooth as it should be. Absolutly no vibration for 10k now after the fix. The dealer RFB'ed 6 new Conties before he got 4 to match. Now I know because of these tires, the nibble might come back but at least I know it can be fixed without replacing the whole front end. BTW, the RFB seats the bead with road force so it will expose a bad tire while balancing rather than sending you home to find out... after the bead seats on your vacation. Bring this post to your dealer and show him that some Ford dealers go the extra distance for their product, even if as in my case, the vehicle is purchased elsewhere.
Old 04-27-2006, 06:38 AM
enskanker
enskanker is offline
enskanker is starting off with a positive reputation.
For $9.99 you can print out all full TSB's for your specific vehicle for up to 3 days.
Longer sign-ups cost more.
http://www.motorcraftservice.com/vdirs/retail/default.asp?pageid=&gutsid=
Its a little confusing they way they set up this site, but work through it and you'll be able to see exactly what the dealer/mechanics see on the TSB's.
The Vibration/run out is an issue with my 2003 Navi also. New Hankook's and still have vibration at 40 - 50 mph.
kkester
50
07-11-2007 04:07 PM
kkester
Car/truck Buying Advice
11-28-2005 08:41 PM
kkester
07-25-2005 02:35 PM
kkester
03-16-2005 09:08 AM
Labrador
2004 - 2008 F150
02-26-2004 08:09 PM
Quick Reply: Looking for Expedition Tire TSB
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
