05 front end conversions guys. Can I just install the lights on my 01???
#32
I know to do it properly you need to buy the 05 header panel and the headlight harness/plugs. The old housings/park lights bolt up differently.
I just don't have the cash to buy a grill and bumper/plus paint the top to match.
Since I have to buy a headlight housing new I'd like to put that cash toward the upgrade.
They no longer carry the lights, but when you are ready to do it certafit over by the airport (canvasback Dr.) has the grill and bumper cheap. They also have the header panel. When you are ready to do it let me know, as I own a body shop about an hour away from you and can hook you up on paint.
#33
#34
this should help you out...
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
#35
Hello...
I've been lurking here for awhile reading different tidbits- but haven't really posted.
I really really want to change out the grill on my 03 X to an 05 style grill. I understand that I need to either trim down a true 05 grill to make it work, or purchase an "after-market" version that is already pre-cut. The only aftermarket grill I have been able to locate is on Ebay- and IMO a bit pricey for a grill.
Can anybody point me in the right direction? I watched the video(s0 in the link- and the person in the video mentions M&M but I can't find this.
Any info would be appreciated.
Thanks.
Mike
Thanks.
Mike
#37
#38
#39
#40
#41
#42
Here they are!
99-04 SUPERDUTY CONVERSION 07 HEADLAMP HEADLIGHTS SET | eBay
Edit: I was wrong, posted to fast. This one says in the discription that you have to cut your header to make these lights fit. That is another option tho.
#44
#45
Just saw this thread is a sticky in the Super Duty forum. here's a very good, detailed step by step complete with part numbers for doing this swap. hope it helps.
http://www.kingkustomstemecula.com/wst_page14.php
Does it show which wire to tap into ?
I wathced the other video and he tapped into the high beam wire (not sure what color ), then grounded, and hooked up the hot side for the relay to work.
HawaiianPSD
07-12-2017 02:56 PM
LeviD
04-29-2017 09:41 PM
Fastcat314
1999 to 2016 Super Duty
10-19-2016 06:18 PM
