What's in your Carry Kit ?
Jumper cables, serpentine belt, 15mm socket, 5/16+wrench, fuses, 3Ton hydraulic floor jack, tires stops, liquid wrench, tire iron, 1headlight bulb-Chiltons, Red Man chaw- circa 2001.
What I don't have that I need:
Relays- which ones?
What else is a must have... Suggestions?
Dutch
Relays- which ones?
Dutch
Relays- which ones?
Dutch
Relays- which ones?
Dutch
DrDutkayp
I carry as standard;
Tow strop + shackles and hooks; Jumper cables; spare fuses; complete set of spare lamps; ECU fault code reader; rags; small tool kit; automotive multimeter; Catagory 3 Hi-Viability Jacket; Work Gloves; Nitrile protective gloves; bolt cutters; wheel brace + selection of sockets; first aid kit; hand lantern (flashlight); chemical lights (omniglows); Haynes & Chilterns manuals; protective seat covers; waterproof cover-alls; amber flashing beacon; steel toe cap wellington boots; rope; cable ties. Also standard survival kit; knife, compass, clothing, water, tarp, fire steel etc.
I will suppliment this with following if I am going further afield;
Spade; Axe; Sledge Hammer; socket set; complete tool kit; extra tow recovery gear; water + snacks;
In the winter;
Sleeping Bag; spare gloves & hat; down jacket; walking boots or neoprene lined hunting wellington boots; survival bag.
Most of the first lot fits in an ammo-tin in the back and the rest usually goes strapped to it to stop it bouncing about. Soft stuff goes into canoe bags to keep it dry.
Might be considered a little OTT by some but I like to be prepared - and also able to help those who are less prepared and caught out.
Simon
In the winter;
Simon
Wow Muckypaws- quite the kit, eh?
I'll take some photos when it stops raining and show you how it all fits in.
Simon
Originally Posted by muckypaws
And when its cold in the winter it usually better to use the wearer of the pantyhose to help keep you warm ;-)
