Check Engine Light came on after switching to E-85
I decided a week or so ago to switch from gas to E-85 on my 03 Ranger FFV. Yes it is a FFV (it has the leaf on the back and the thing on the gas flap)...I had 69000 miles on it and have run gas in it the whole time. Switched to E-85 (have about 250 miles on E-85 now) and this morning while driving to work the "Check engine" light came on.
I have a feeling this has to do with switching to E-85 as everything else (gauges) look fine. I read something about the oxygen sensor gets goofed up because its not use to seeing E-85 in the tank and thats why it came on.
What should I do? Should I switch back to regular gas as soon as i can or do I need to take it to the repair shop and have it looked at?
03 Ranger
3.0 L engine
FFV
69000 miles
03 Ranger
3.0 L engine
FFV
69000 miles
Originally Posted by PSKSAM2
Pull the codes.
This could be something as simple stupid/simple. Who knows?? I would not jump to conclusions. It could very well be coincidental that the light came on after swithcing fuels.
she was and i am not, i have a ffv but i dont have any stations around here. id be willing to try a tank
Matt
p.s. THE HONDA PPL TOLD HER TO LET THE CAR RUN AND AFTER A COUPLE OF TANKS THE CODE WOULD GO OFF
Matt
Originally Posted by Iceberg
Is she running E-85 in it?
I take it you arent running it in your 00 Ranger?
Originally Posted by texan2004
Exactly. Until you do this, you have no idea what the problem may be. How does the truck perform on ht E-85??
I'm not vehicle savvy...what does this mean?
These are sometimes called DTC's ("Diagnostic Trouble Codes") or OBD-II (On-Board Diagnostics) codes which is the type that Ford and other manufacturers now use. You'll see a lot of threads on the board about specific codes that people have seen (ie P0171/P0174 are lean codes).
More info:
http://www.obdii.com/background.html
-Jim
I like Jim's idea to get the computer scanned for codes & post ALL that are found.
If you don't find any codes, try pulling the computers power fuse, in the under hood power distribution box, for 30 minutes, so it'll have to relearn some fuel trim things with the current E-85/gas mix.
As this tank is a mix of E-85 and regular gas, & you didn't say how far down you ran it, before filling with E-85, don't be surprised if it gets confused when you fill up again, as the ethanol to gas ratio will change again.
It might help if you run this tank almost dry, say below the 1/4 mark, before refilling. My owners manual says it's not out of the question for the CEL to stay on for 3 tanks, if the E-85 fuel quaity isn't good.
You'll also want to keep a eye on your crank case lubes condition, as I've read, some formulations don't like high concentrations of ethanol in the fuel.
You might go as far as contacting your oil manufacturers technical department & see if there will likely be any long term issues with you using E-85.
Just some thoughts for pondering.
Let us know how it goes.
Pawpaw
Thanks for the insight…Here is what happened
4/12 got the idea to run E-85…Put 12 gallons of E-85 in. So this tank was 4.5 gal gas and 12 gal E-85
I drive 32 miles one way to work
4/15 filled up with E-85. Had over 130 miles on the truck (truck can get about 320 on a tank of gas) so I figured the unleaded was out. Put in 6+ gallons
4//17 knew they would jack gas up on Tuesday, so I put in 5 gallons of E-85.
4/18 CEL came on. I had driven about 15 miles since filling up 4/17
So I think the computer finally realized after filling up on 4/17 that “hey wait a minute…where is the 90/10 gas” (MN has 10% ethanol in their gas year round) and the CEL came on
As for the oil, I know this sounds stupid but I take it to the Ford dealer. The way the oil filter is on the 3.0 (in the most screwed up spot) my hands are too big to get to it. So I just take it to the sister dealer of where I got it (the dealer I bought it from is 30 miles away and they purchased the dealer in my town about 2 years ago) so they use 5W-20 in it with the motorcraft filter.
I’m going to swing by my local Checker Auto parts and get the computer to read the codes and post them..
So you think once the computer figures out I’m running E-85, the CEL will go off?
