Fuel pump to inside the tank.
Originally Posted by John7894
Kwik,
Can you list the name/part number of that pump?
You got my wheels turning considering I still need to do the Hutch mods to my tank.
Or Bosch part number: 0 580 254 957
Or the short Bosch part number: 69 430
You must drill out the check valve in the outlet of the pump or it will not flow enough. The check valve is contained in the little steel fitting that screws into the outlet of the pump so you can simply remove it, drill it out and reinstall. Or simply remove it and use an alternate form of plumbing to get the job done. Just don't try and run with the check valve. Not enough flow. Not having a check valve is a non-issue. The truck starts easier without one for some reason.
Originally Posted by jtharvey
Kwik, do you think it would be beneficial to drill out the check valve on a pump that is still mounted to the frame?
Update:
I went out this morning and it was cold enough for the door to be iced shut this morning, so it was a good test for a cold start.
I turned the key and the pump made the same noise!!!
There's no way that it's starving for fuel in it's current location, so now I'm wondering if maybe I just have too much Bio-diesel in the tank and it's jelling in the freezing weather. Funny part about it is the noise goes away as soon as I start the engine. I even went back and listened to make sure.
Oh well, at least I can be confident that there is no way for air to get into the fuel.
Originally Posted by simms63ss
kwik, your fuel pump noise before start up is just from the pump bulk heading. the pump gets quiet after start up because the fuel has somewhere to go.the fuel pumps on all my race cars would do the same thing. might not be 100% right, but i might be close.
simms
simms
