Sponsored by: Auxito
2001 Power Mirrors Quit Working! Help!!
Old Apr 17, 2006 | 03:38 PM
S & K Racing's Avatar
S & K Racing
my power mirror both quit working at the same time but i am not having any other problems. I checked all the fuses and they are fine. Any ideas what would cause this?
thanks
stuart
Old Apr 17, 2006 | 03:56 PM
92merc's Avatar
92merc
Both sides quit working? You could start by pulling the panel off the door and making sure the connector is still hooked up.
Old Apr 17, 2006 | 04:09 PM
S & K Racing
thats what i will do next
Old Apr 17, 2006 | 06:13 PM
S & K Racing
Smile
I ended up taking the control switch out and tested it. It was not working so I took a small flat screw driver and unsnapped and seperated it. It was very tarnished. It has a insert inside that slides out which has the contacts on it so i removed it and cleaned with a pencil erarser then spray with contact cleaner I did the same thing on the pin contacts where the harness plugs in. This all took about 20 minutes but now works great and I am sure it was worth the time compared to the price of a new control. I hope this may also help someone else.
thanks again,
Stuart
<!-- / message -->
Old Apr 18, 2006 | 12:44 AM
Racerguy's Avatar
Racerguy
Welcome to the forum Stuart
Thanks for letting us know what fixed it.
Old Apr 20, 2006 | 06:55 AM
99 Ford's Avatar
99 Ford
I have the same problem with my 99 F-150. How difficult was it to take off the door panel? Any hints to make it easier?
Thanks.
Old Apr 20, 2006 | 05:30 PM
S & K Racing
on mine I just had to pop the panel that the control is in off by starting at the front by the control then it lifts up and forward.
Old Apr 21, 2006 | 09:05 AM
99 Ford's Avatar
99 Ford
Thanks S&K Racing! I'll give it a try.
