Frame Mount help
Old Sep 16, 2002 | 06:30 PM
canuck's Avatar
canuck
Frame Mount help
Hi!
I just obtain some frame mounts out of a 1977 302 Ford truck to use on my 1968 Mercury truck. When I placed them on, the bottom two holes do not fit. Do I have to drill thoses two holes out on both sides or
I am missing something here?
Thanks,
Terry
Old Sep 17, 2002 | 05:26 AM
jowilker's Avatar
jowilker
Frame Mount help
Terry, can you be a touch more specific on which mounts you are referring to ?
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Sep 17, 2002 | 06:46 PM
canuck's Avatar
canuck
Frame Mount help
Sorry, if I was not clear enough on the last posting.
What I mean is the where the frame mounts attach to the frame mounting holes.
Thanks
Terry
Old Sep 18, 2002 | 07:23 AM
stroker393's Avatar
stroker393
Post Frame Mount help
I had sort of the same problem. I obtained mount towers from a '76 302 to go in my 69 F-100 to install a 351W with 4-speed. I first bolted in the drivers side tower with the top two bolts and then lined up the passengers side with it. Both towers were installed using existing bolt holes then I mounted my engine to check line up with my frame clutch pivot and the one on the block. They lined up correctly. I pulled engine back out and both towers were lined up on two existing front bolt holes in the cross member but had to drill two new holes for the lower rear ones. Hope this info helped.
Old Sep 18, 2002 | 07:27 AM
jeremyd72's Avatar
jeremyd72
Frame Mount help
