91 300 distributor
Old Apr 15, 2006 | 10:39 AM
camarodave's Avatar
camarodave
91 300 distributor
i replaced plugs/ wires and i went to take the dis. cap off and one of the screws broke. im trying to take the distributor out to get the screw out but i cant get the distributor out of the block. i did take the bolt and the hold down off. looks like another pin holding it in?? please help.
Old Apr 15, 2006 | 10:49 AM
4.9inline6's Avatar
4.9inline6
on my 93, if you take out the hold down, dist should slip right out...now remember to mark where it came out so you don't have to redo all the spark timing.
chris
Old Apr 15, 2006 | 10:51 AM
camarodave's Avatar
camarodave
its marked and i took pictures to be sure. the dis. will rotate but the shaft wont budge. ill go bake out and give it hell. i was hoping there would be somtihng i was missing.
Old Apr 15, 2006 | 01:31 PM
camarodave's Avatar
camarodave
its out. the screw is still stuck.
Old Apr 16, 2006 | 10:37 AM
4.9inline6's Avatar
4.9inline6
screw extractor, drill and tap - couple of methods i would recommend. good luck.
chris
