I got a new truck
I got a new truck
Hi guys I just bought a 1970 f-100 2wd with a 302 in it and a four speed, I got it for 280 dollars (canadian) , after I adjusted the clutch it has only some minor problems
1. The drivers side front signal light workes for signalling but will not work when I just put on the driving lights
2. The four way flashers will not blink they act as a solid light
3. the lip around the filler spout for the incab gas tank is bent in on the bottom and bent out on the top
any help on these problems will be much appreciated
Steve
PS what are some cheap mods I can do for a little more power without losing much of my fuel mileage!:7
1970 F-100 Custom 302 3bbl 4 on the floor, its my "economy machine"
1970 F-100 Sport Custom 390 2bbl 3 in the tree with factory overdrive.
1978 F-150 Custom turned into a dune buggy 300-I6 4 speed
Im a typical teen, i just have to change it
Steve
I got a new truck
1)There should be ONE bulb with TWO filaments in that light.
One for Signal & One for a Running light.
Check the bulb and replace it.
(Or does this just have one function only?)
2)Replace the flasher.
3) ?
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
3) ?
[/font]
I got a new truck
Thanks dennis I will change out that bulb tommorow also is there a possibility of a bad ground?
Thanks
Steve
1970 f-100 Custom 302 2bbl 4 on the floor, my "economy" machine
Im a typical teen, i just have to change it!
Thanks
Steve
I got a new truck
Some things I did to my 302 that increase perfomance and gas milage;
-Headers and dual exhaust.
-Swap out ignition points for a Pertronix unit and then replace coil with their flame thrower.
-Replaced automatic choke with manual setup.
-Make sure throttle linkage opens throttle up all the way when you put your foot to the floor.
I got a new truck
Thanx Mil1ion and Sedric
Just another question but what size of pipe would you guys use in your trucks with 302's I am looking at 2 1/4 does that seem high flow enough
Steve
1970 f-100 Custom 302 2bbl 4 on the floor, my "economy" machine 1970 F-100 Sport Custom 390 2bbl 3 in the tree with factory overdrive.
Steve
I got a new truck
[updated:LAST EDITED ON 23-Sep-02 AT 02:29 PM (EST)]Thanx again
I replaced the bulb yesterday, but the socket is so rusty it has a hole right through it. I can get the flashers to go on but that light does not flash, although it does work on the driving light setting (it never flashes).
Steve
PS all information you give me is crucial as I am about to turn 16 (october 16) and I plan to have my truck on the road the first day I have my licence so it has to be street legal by then, thanks again
Steve
lb,douglas
27
09-14-2019 07:34 PM
speedking390
11-27-2011 01:30 AM
skfinch
09-17-2006 12:39 PM
