Best way to install tool box
I've searched the forum with no luck so now I'm asking the stupid question....What is the best way to install a tool box that mounts flush (sort of like a low profile box vs a box that hangs over the bed rails) with the bed of the truck?
I don't have any liners but I do have a thick rubber mat made for the bed of the F250. I'm wondering should I just drill the hole through the box, rubber mat, and use self tapping screws (I think the screws are 1/4 or 5/16)??? Should I include chaulk, gasket sealer, or something else??? Should I cut the rubber mat flush with the tool box (in case I need to remove it for cleaning)???
Thanks in advance for answering my dumb question of the day!
I know from experience that sheet metal screws through the heavy rubber mat don't work. I've never had a problem with them directly into the bed or through spray on liner, though. I have bolted them down, too. The bed bolt idea might work - I'm not sure offhand just where the fronts are located since mine are covered up with my toolbox, but be sure they're long enough if you're going through a heavy rubber mat. I think I'd just use 4 bolts with big washers on both sides. Good luck with whatever you decide on.
David
David
I may be different, but I just set it in there and use a 2X2 along the back to wedge against the wheel well. I don't keep that much in it and it is real easy to take in and out for hauling. The only time there is much in it is when I am towing the trailer and it is pretty heavy then.
Frank
Frank
This is how I did it in the past...
Place the tool box exactly where you want it. Then trace around the tool box onto the rubber bed mat. Remove the tool box and rubber bed mat. Cut the rubber bed mat to fit the tool box.
Now with the rubber bed mat still out of your SD...place your tool box in the same location as before. Measure and mark 4 locations for the bolt holes. I would recommend 3/8" bolts...just for peace of mind. Of course...make certain nothing below the bed gets a hole too.
You can use a good quality gasket maker to help seal the holes.
Good luck...
biz
________________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Good luck...
biz
My '90 F250 had the factory in-the-box spare tire mount, but the tire was mounted underneath. I used this tire-mounting surface with a bolt and nut to anchor a plastic in-bed toolbox to keep it from tipping or sliding. You could fab a piece of steel from the lip of the bed down to where the box curves, and bolt your toolbox to that. This would avoid punching holes in your rubber mat or the bed floor.
Steve
Steve
Here is a link to the install I did. http://www.picturetrail.com/gallery/...3562&members=1
I have had zero movement in the box and didn't have to drill holes in the bottom that might let water in should I need to help Noah build another ark
It also allows me to remove the box quickly if I need to make a dump run and need the space.
Originally Posted by Munkey
Cmpr,
Wow, neat, woulda never thought of that!
Just how hard is it to remove that box? Around here, everything seems to grow legs and take up residence at a pawn shop.
I thought about putting a bike lock, the long shank kind, through the trucks tie down then through the turn buckles to keep them from being unscrewed...never did it. Another thought was a chain running from turn buckle to turn buckle behind the box would do the same thing. I had to space the box rearward from the front of the bed so the lid would open leaving room for that setup. I should have used sturdier hardware on the box as it wouldn't be too hard to just bend them out of the way.
This just keeps the mostly honest people honest.
Hogtrapper
23
08-16-2015 12:33 PM
Bob Landry
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
04-16-2013 07:01 PM
