56 door adjustment
Old Apr 10, 2006 | 12:35 PM
wiseguy50's Avatar
wiseguy50
Smile 56 door adjustment
i need to bring the doors "in" a little as i get a lot of wind noise. i do have rubber around the outer doors but it seems as though they dont seal when closed
the lower part of the door is fine, its fron the door handle up that needs to come in. do the hinges adjust in as well as up and down? am i making any sense? thanks for any input.
Old Apr 10, 2006 | 01:08 PM
fatfords's Avatar
fatfords
Wiseguy,
I don't have my manual in front of me, but I thing the hinge bolts can be loosened and the hinge moved inward on the A pillar. If memory serves, there is a third bolt deep inside the hinge that also must be loosened to make this adjustment.
If no one else jumps in here to verify, I will check my manual and take a look at my hinges tonight.
Good Luck!
Old Apr 10, 2006 | 01:14 PM
fatfenders56's Avatar
fatfenders56
if it's off at the top rear try bending the door in at the top, it's pretty easy to do
Old Apr 10, 2006 | 02:14 PM
Randy Jack's Avatar
Randy Jack
A Shop Manual would be an excellent investment. It outlines every way that the door can be adjusted, including the bending that FF56 is talking about. I would try the hinge adjustment that fatfords mentioned first. If that isn't enough, bend it.
Motorhaven sells the manuals and they can be had on ebay.
Old Apr 10, 2006 | 02:28 PM
eberhama's Avatar
eberhama
The hinge really won't move, you're pretty much stuck bending. When I was making my 56 doors fit, I was surprised how little bending it took to make them fit great.
Old Apr 10, 2006 | 07:25 PM
imlowr2's Avatar
imlowr2
LOL.... I know this method makes sense to truck owners and I've done it before, but how do you explain to someone that your door doesn't align correctly so, "I bent it"? Too bad the hood, fenders and everything else doesn't work this way....
Old Apr 27, 2006 | 11:56 PM
ona6day's Avatar
ona6day
Just saw this post, could you tell me how to bend the door?
Old Apr 28, 2006 | 01:20 AM
WillyB's Avatar
WillyB
Brace your knees just below the window, grab the top with your hands, and pull!!
When I was a kid we had this little guy bodyman that had worked the MACK truck assembly line - he was like a monkey climbing around the cab and "adjusting" the doors.
The first time I tried it the dang door folded like it was made of cardboard - made my boss so mad he took the price of a used door out of my pay check - and he only paid me $10 a week to clean parts after school!
ggwash21
Jun 13, 2009 07:05 PM
those70'sfords
15
Feb 12, 2008 02:16 AM
Bill_T
May 8, 2007 11:24 PM
sdetweil
Aug 14, 2005 11:45 AM
53Merc
Nov 9, 2004 09:23 PM
