ballast resistor
ballast resistor
what is a ballast resistor?
i have a 1970 f-100 with a 302 and im trying to install a pertronix ignition system it says i need to connect the red wire from the ignitor to a connection before the ballast resistor...what do ya'll reccomend...im using the stock coil for now...thanks guys
ballast resistor
[updated:LAST EDITED ON 22-Oct-02 AT 01:53 PM (EST)]The ballast resistor reduces the amount of voltage to your points style distributor. If you run the full 12 volts to your points, you risk burning them. Which is not good, so I have heard. :] If you are running a pertronix conversion or electronic ignition you do not need the resistor. Anyone else chime in if I am incorrect on any of these points (pun NOT intended).
rasmuspa
06-27-2016 01:36 PM
ihcc104
04-16-2016 08:13 PM
Tparkin99
29
03-27-2016 10:30 PM
FORDF250HDXLT
11-22-2015 08:53 AM
himmelberg
48
09-21-2004 02:59 PM
