Auburn Gear Question?
Originally Posted by PERFORMANCE RED
I am looking at getting an Auburn Pro series L/S but I can not find one for 37 spline axles.
I have an 06 F-350 V-10 SRW. The research I have done says it has 37 spline axles. Correct me if I am wrong please.
Where can I get a L/S for my truck?
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Originally Posted by biz4two
What rear do you have? We are talking about the rear? Do you have the Ford 10.50" or the Dana80?
biz
biz
From what I read from on here is says it has 37 spline axle???
http://www.mustangmods.com/ims/u/2088/3609/39478.jpg
If i'm reading the catalog correct, the axles are the same with or without Limted slip. The ring and pinon looks the same also. so if you add the factory Differential Assy Ford part # F75Z 4026-DA 2 Pinion 6.8L Gas EFI V10 Ford 350 Series All Wide Frame Wheelbases With Single Rear Wheels Rear Axle Limited Slip Differential it should work.
<br>
LIST $331.13 FTE $238.42 PLUS SHIPPING
<BR>
Ed
<br>
<BR>
Ed
I believe it is a 10.50 because it is only a SRW. Only the duelies came with the Dana 80. And its a 4.10 open rear end.
biz
