1978 - 1996 Big Bronco
Rear tire
Old Apr 3, 2006 | 04:41 PM
wjawill's Avatar
wjawill
Rear tire
My rear tire is rusted on really good. Any one got any tips on getting it off?
I loosened the lugs and drove around a bit and it didn't budge. Already sprayed it with a ton of pb blaster. Is it ok to put a torch on the middle part thats rusted? Or will this mess up the wheel and axle?
Thanks for any and all help.
Old Apr 3, 2006 | 04:51 PM
dwoodler's Avatar
dwoodler
Put it on blocks and make sure it is really rock solid. Take the lug nuts off, then use a 5lb/10lb/12lb sledge and slap the tire from the inside out. If you can't get it that way, then then only thing left is to bang on the rim itself. A tire shop my buddy used to work at would have to do this all the time when removing aluminum rims. They corode on really good. Try to hit the rim square though and this reduces the chance of bending anything.
Old Apr 4, 2006 | 06:54 AM
BillyBob69's Avatar
BillyBob69
What dwoodler said. But you may have to go straight to the rim with the hammer...from the backside out. Toyota 4 Runners are notorius for that same prob so my wife carries a small sledge in hers just in case she gets a flat.
Old Apr 4, 2006 | 10:21 AM
wjawill's Avatar
wjawill
Ya they are aluminum rims. I didn't want to bend the rim thats why I didn't try that. But its got to come off.
Thanks for the help
Old Apr 4, 2006 | 10:48 AM
BillyBob69's Avatar
BillyBob69
You shouldn't have to hit it real hard...just enough to break loose the rust seal...then you can pull it off normally. It only needs a little shock.
Old Apr 4, 2006 | 04:27 PM
Streetgang's Avatar
Streetgang
Hold a 2X4 against the inside of the rim to protect it from damage, and smack the hell out of it with a big hammer.
Old Apr 4, 2006 | 04:34 PM
yamaweezle's Avatar
yamaweezle
where i work, i use a heavy plastic dead blow hammer to hit the tire/rim with...transfers the hit very well, and doesn't damage the rim either...
