reprogramming remote locks
Old Apr 2, 2006 | 09:07 PM
plb7732's Avatar
plb7732
I just replaced the security module in my 2002 f-250 and now my remote locks don't work. Does any one know how to reprogram them? thanks
Old Apr 2, 2006 | 09:20 PM
maevans's Avatar
maevans
Give this a try -https://www.ford-trucks.com/forums/showthread.php?t=467084
Old Apr 2, 2006 | 09:33 PM
hllon4whls's Avatar
hllon4whls
This definately works. You dont have to kill yourself and it may take a couple of times before you get it. Dont do anything else in programming mode because you may change some other features unwillingly. You can have up to 4 remotes for any truck. Any ford remote tends to work, even the ones for cars on a truck, etc.
Old Apr 2, 2006 | 11:26 PM
SpringerPop's Avatar
SpringerPop
The entire procedure is actually in the Owner's Manual.
Pop
Old Apr 3, 2006 | 07:27 PM
Muktown's Avatar
Muktown
cycle your ignition on and off 5 times without starting it ending in the on position. the locks will lock and unlock. hit a button on the transmitter and the locks will cycle again turn the ignition off and you are done. the stealership by me wanted $40 for those 5 seconds of work
Old Apr 3, 2006 | 10:01 PM
Lushman's Avatar
Lushman
I tried the procedure in the manual and it didn't work. Some tips people sent to me were to unlock the doors with a key when getting in and then lock the doors behind you. If you have a factory installed alarm (and not just the keyless entry) it is supposedly 8 times turning the ignition on and off. Mine never worked. I was working on my truck later that weekend and had to disconnect the batteries. I firgured I would try it again the next day and it worked for some reason, go figure! If all else fails, disconnect the batteries and try again!
Kramer73
Australia Chapter
20
May 3, 2018 03:22 PM
mmenzies
Feb 26, 2015 06:17 PM
jsfiat
Feb 5, 2015 09:30 PM
CaptKen
Sep 19, 2013 06:17 PM
mgissen
Aug 11, 2004 09:58 PM
