Proposed Gas Tank Relocate
#31
[updated:LAST EDITED ON 15-Nov-02 AT 07:36 PM (EST)]I went Big!
I just installed a 90 gallon L shaped tank in the bed. Unfortunately for now, it is white. It was about $330 at a local truck and trailer store. If I think I can get inspected with this setup, I will remove the cab tank. 90 Gallons ought to be enough. For now, it doesn't look nearly as good as Truck35's setup, but I will eventually paint it with the rest of the truck.
I'll put up some pics soon.
#32
I am new member to this website but so far have been impressed. Its good to have access to such a wide selection of Ford Truck minds. I own a 1969 F-250 and I did not like the gas tank behind the seat settup- or the side mounted one actually. I ended up getting a tank from a 73` Chevy (yes, I know, but what the hell, I figured I at least did some damage to the worthless Chevy when I ripped out her tank) and I mounted it between the rails in the very back of my truck. I have then since shaved EVERYTHING so it looks very nice and I am very happy with it. I had tp buy an aftermarket sender but it was cheap and easy to do. I think thats the way to go- but it all depends on what your goal with the truck is. I steered away from the "classic" look and have gone for a bit more modern look. Hope it helps a little.
#33
#34
#35
GolferSA
Electrical Systems/Wiring
09-07-2021 05:17 PM
bobj49f2
106
03-30-2021 05:29 AM
kabcpapc
1983 - 2012 Ranger & B-Series
03-24-2006 01:20 AM
GolferSA
09-08-2002 09:57 PM
