Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Cement
Old Mar 31, 2006 | 04:23 PM
old farmer's Avatar
old farmer
Cement
What is a good thing to fill a crack in a basement wall from the outside, or what worked good for you? Thanks.
Old Mar 31, 2006 | 05:01 PM
karljay's Avatar
karljay
found some sealer @ home depot just for that, forget the name, but it comes in one of those caulking gun tubes and was < $10 if I remember right.
Old Mar 31, 2006 | 06:40 PM
ItzKwik's Avatar
ItzKwik
I think its Sikka, not sure of the spelling. Use it alot at work. Good stuff.
Old Mar 31, 2006 | 06:46 PM
fellro86's Avatar
fellro86
Bentonite works pretty good, basically, it is cat litter. Spread a bunch out around the wall, and when it rains, it will drive it into the soil, then it will seal the crack underground. It actually does work, had a cinder block wall that leaked all the time, and after I did that, it stopped.
Old Apr 7, 2006 | 10:37 PM
chrono4's Avatar
chrono4
fellro, so that would work for an underground leak in a floor? a teacher of mine got an adition, and the rain water forces up inbetween the cracks, would that fix it?
Old Apr 8, 2006 | 05:55 AM
fellro86's Avatar
fellro86
can't say on that short of having to tear into it a bit, unless you go to a hardware store and get some of the concrete patch they have there, it worked for leaks on the inside of the wall here, the chimney actually was allowing water into it undergraound, so I covered it with tin, then allpied the concrete patch over it, still working pretty good. The bentonite trick works mainly for seeping, bnig leaks need to be covered with the patch.
kid1994
13
Jun 1, 2012 10:26 PM
Placermike
Washington Chapter
Jun 4, 2009 09:09 PM
87Mater
15
Jan 25, 2009 01:08 PM
KCMAGERS
May 8, 2007 12:36 AM
jowilker
Jul 18, 2002 03:17 AM
