pull turbo/wicked wheel
i pulled my turbo. going to pull it again this week or next week. (other mods/rebuild). it is not hard to do, just takes some time. there is a great writeup i have that i can give to you that goes through it in depth. you get better at it every time, hopefully you'll only need to do it once. i am pulling mine for the fourth time.
Kris, which O-rings are you replacing each time, just the 2 on top of the pedastal or all of them? I have the 2 that came with my WW, but saw this kit from KCM: http://members.***.net/kcmdieselperformance/gaskets.htm
i tear the pedestal off and replace the lower rings too. i use the KCM diesel turbo bolt kit and seal kit. with blue bolts.i figure why not? you have them in the kit, you only need to remove 4 EASY 10mm bolts, and thats it. plus theyre oversize.
i have a whole new kit from KCM waiting in my box, (along with the new 7 pc. bolt kit) that im going to replace the o-rings again. plus a complete rebuild kit.
Firefighter 1406
44
04-10-2014 12:58 PM
messeswithtrux
16
11-26-2007 09:54 AM
