Mass Air conversion
Old Mar 28, 2006 | 10:46 PM
dhag911's Avatar
dhag911
Mass Air conversion
I know that this has been talked about alot but i spent 2 hours going through previous forums and found nothing i was really looking for.
I have a 1992 F-150 302 E4OD.
I have found 3 pickups with mass air i dont know for sure yet what there transmission is yet. If they have the same transmission what do I need out of the truck? Do they have to be the same engine size?
Old Mar 29, 2006 | 08:46 AM
LoosMaster's Avatar
LoosMaster
http://fordfuelinjection.com/?p=5
This site gives alot of info on it. Engine size doesn't matter because the MAF sensor detects changes, that's why it's so desireable.
Old Mar 29, 2006 | 09:09 AM
Kemicalburns's Avatar
Kemicalburns
you will need the entire harness, maf sensor, and computer. dont get any of this if its off of a 96 though. that would be an obd-II setup and is not that great.
Old Mar 29, 2006 | 09:44 AM
dhag911's Avatar
dhag911
I will also need another O2 sensor right?
Old Mar 29, 2006 | 10:25 AM
Kemicalburns
not usually. the trucks running mass air had only 1 till 96 when they went to 3.
Old Mar 29, 2006 | 04:04 PM
dhag911's Avatar
dhag911
do you know what the part number on the computer would be?
does it matter if the trucks have ABS or not?
How would i be able to tell if i need the extra O2 sensor?
So what I gathered from ford fuel injection i need one of three computers
HUG2
VEX1 5.0 Bronco, F-x50 E-x50 MAF / E4OD / F5TF-12A650-HB (see note 1)
WAY1 5.0 Bronco, F-x50 E-x50 MAF / E4OD / F5TF-12A650-JB (see note 1)
Old Mar 29, 2006 | 04:45 PM
Kemicalburns
why are you wanting to go maf in the first place?
Old Mar 29, 2006 | 06:41 PM
dhag911's Avatar
dhag911
I have some mods done and there is a couple 95-96 f-150s that have mass air and they want $100 for all of it.
Old Mar 31, 2006 | 12:55 PM
dhag911's Avatar
dhag911
would i be able to get all the wiring and air flow sensor from a 96 and a computer from a 95
Old Mar 31, 2006 | 02:32 PM
EPNCSU2006's Avatar
EPNCSU2006
No. The 96 computer is a 105 pin or something like that, while the 95-older computers are 60 pin. The business ends of the wiring might be the same, but you can't connect the 96 harness to the 95 computer.
Old Mar 31, 2006 | 03:08 PM
Kemicalburns
what mods? because most dont require mass air. and you could probably work fine running speed density and save the money & time for other things
Old Apr 24, 2007 | 10:51 PM
dhag911's Avatar
dhag911
HUG2
Well now that me and my dad have some time we want to make this little 302 have a few more *****. we want to pull the engine and bore it out convert to mass air and add a supercharger and probably throw in a cam while we have it out. just checking if these are the right computers to look for?
Old Apr 24, 2007 | 10:58 PM
taisa899's Avatar
taisa899
the Vex1 and the Way1 will work for you because they are OBD1 and it's a 60 pin ECU. Not sure about the tranny in the HUG2 but as long as it's for and E4OD tranny it will worlk for you. If you need a HUG2 let me know cause i got one here that works perfectly
Jim
Old Apr 25, 2007 | 06:44 PM
lostin90s's Avatar
lostin90s
Just stick with everything from 95 down . 1 O2 . get all harness(motor and engine bay) it will fall right in place of yours.I take old (non Maf) and new engine bay harness and keep everything for old cab connections and use the new for running the ECM and merge the 2. Because the in cab connections are different but you can figure that out. The air sensor on front of your intake is moved to the Maf airbox. You will need air intake hoses ,MAF and air box .
biofused1
Feb 3, 2015 01:42 PM
kameronth
1978 - 1996 Big Bronco
Apr 11, 2006 06:02 AM
jjoel
Jul 7, 2005 04:30 PM
snowmobilerfreak
Aug 9, 2004 10:23 AM
Tdawg123
Jun 25, 2002 11:47 AM
