Modulars In Older Trucks - Ford Truck Enthusiasts Forums
Old 03-26-2006, 11:05 PM
johntucker09's Avatar
johntucker09
johntucker09 is offline
johntucker09 is gaining momentum as a positive member of FTE.
Has anyone seen or know any links to pictures of a modular being installed in an older truck? I've seen some pics of one installed in an Old Bronco, but I was hopeing for something a little more detailed.
Just an idea I was pondering for when I win the lottery...
Old 03-27-2006, 05:08 AM
7700Rob
7700Rob is offline
7700Rob is starting off with a positive reputation.
Well, I saw saw something off the subject, but worth bringing up . I once saw in a magazine, a '61 Sunliner with a DOHC 4.6 and all of the air ride suspension from Town Car. Very cool at the time.
Old 03-27-2006, 05:16 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
i have played with the idea. I have considered a 5.4 swap. the engine swap and trans is simple. what really takes the time is the wiring and plumbing. You also need to find a way to mount the entire steering column from the donor truck due to the PATS system. Or take the easy route and grab a 5.4 from a SD with no PATS system. You could do the swap in a month or 2 if you spend the weekends doing it. I can get a wrecked SD for 6,000.00 and still be able to sell it for 3k when i pull the trans and engine. insurance auctions are the best place to find these.
Old 03-28-2006, 12:03 AM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.
Looks like Im doing the opposite....LOL
Im going to put a 460 in place of my 4.6
Old 03-28-2006, 09:39 AM
Lwlandy's Avatar
Lwlandy
Lwlandy is offline
Lwlandy is gaining momentum as a positive member of FTE.
I am in the process of fitting a 4.6 to my 1956 F100. The project F100 from Air ride has a 4.6 installed. You can see the end resilt on their website http://www.ridetech.com/companyprojects/f100.asp But there is not much info on the install.
Cheers
Lee
Old 04-09-2006, 08:48 AM
mgraveman
mgraveman is offline
mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.
i am looking at doing this now - all the parts are free.....
Old 04-19-2006, 09:46 PM
F1/100&150Bill
F1/100&150Bill is offline
F1/100&150Bill is starting off with a positive reputation.
just finished a swap in my '50 F-1 , already had a 351 from a Cougar and the front clip.Found a '97 Mustang conv hit on the pass. side and insurance totaled it, 48K miles. Some of the challenges are oil pan must be cut at the flange and reversed, drs side exhaust header cut at the flange and turned - welded. remote oil filter mount. I had the whole car so I took anything I needed - all wiring and computers, complete engine with ps, ac, brakes are great and I gained room by not having vacuum booster, crusie control - radiator with fan. My choice was to use what the car offered and that meant using the steering column and the instrument cluster which was another challenge. Now finished I've got a smooth good looking ride with dependable power and fair gas mileage (20+) but it is a real sleeper from the outside. Pics if you are interested.
Old 04-20-2006, 10:43 AM
bryyce62's Avatar
bryyce62
bryyce62 is offline
bryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud of
Pics for sure. Let everybody see them.
gw
Old 04-20-2006, 03:45 PM
captain p4's Avatar
captain p4
captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
How does it move compared to the 351? Obviously not a fair comparison displacement wise, but maybe having both engines in the same vehicle would give some better perspective... that is if you ever ran it with the 351 in there.
Old 04-20-2006, 04:57 PM
F1/100&150Bill
The 351 was running when I pulled it and gave it to another hot rodder, it was from a 77 or 78 cougar which was low compression and didn't wind up like the Mustang engine and I gained about 80 hp, big difference with aode transmission as compared to the FMX..Best answer is it sure has more *****.
Old 04-20-2006, 05:08 PM
mgraveman
I've driven the 5.4 - and it has a lot more than the 400 in my truck. I'll be doing the swap in a few weeks.
My 400 runs great - just low on power and terrible mileage.
Old 04-20-2006, 09:47 PM
captain p4's Avatar
captain p4
Thats kind of what i was expecting. A lot of guys around here won't admit that the mod engines are better engines than their predecessors because they 'feel slower' but they are generally in much heavier trucks. The 5.4 would have even more ***** then the 4.6. Thanks for the first hand info
Old 04-20-2006, 10:16 PM
Krewat's Avatar
Krewat
Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
I got into my '96 t-bird w/4.6L brand-new and realized the motor was quite a lot different than even a roller-5.0
It immediately seems to have MUCH less internal friction. Which just means more power makes it out the end of the crankshaft
Either that, or the stroke, or something... but a totally different animal than, say, an FE, or SB Ford (289), or 351m, etc.
I keep bringing it up, but it was a good experience I had with OHC's, and the Triumph TR7 4-banger acted the same way. I'm pretty certain what I feel different is the difference between big valve-springs/lifters/pushrods vs. lash adjusters that do not move, very small "followers" and lighter springs pushing back. The circumferential(?) inertia from the extra cams doesn't seem to be a big problem, nor the weight of the chains.
Nice motors...
Old 04-21-2006, 10:04 AM
skilife17's Avatar
skilife17
skilife17 is offline
skilife17 is starting off with a positive reputation.
I saw a guy with an F100 at a car show here in MN a couple years ago. He dropped in the V-10 drivetrain. It fit in there fire wall was knocked back a few inches.
Old 04-21-2006, 10:34 AM
mgraveman
Nice motors...
I wouldn't have considered this swap I am doing ('97 5.4 into 82 F350), but I LOVE my wife's town car. There's nothing like getting 30 mpg on the two land highways. She averages 22-23 mpg every tank all day long, and we can get 24-25 on the interstate. I love these engines. Why buy a silly little honda? We have a real car, paid less than a honda costs, and the mileage isn't that big a deal.
Quick Reply: Modulars In Older Trucks
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
