Leafspring Replacement
Old Mar 25, 2006 | 01:14 PM
WOFP's Avatar
WOFP
Question Leafspring Replacement
2WD 1967 F-100. Is this a difficult DIY job? How do I know on the rear suspension if I have the "with or without aux springs" version?
Old Mar 25, 2006 | 02:21 PM
Ford_Six's Avatar
Ford_Six
Not too hard to do, easier if you have an engine hoist to lift the rear of the truck. Make sure you support the truck on the frame, though.
Aux. springs on that year truck is a secondary leaf pack that sat on top of the main leaf, and had it's own pair of stops it hit to work. There was also the flex-o-matic setup, which was an odd looking s-shaped bracket on the rear of the spring, which effectively shortened the spring when the truck was loaded, making it a two-stage leaf. IIRC, these springs were about two inches longer, but I -think- you can replace the assembly with a standar shackle and run regular springs.
Old Mar 25, 2006 | 06:59 PM
WOFP's Avatar
WOFP
Alright, Jared; I'm going to order replacement leaf springs thru LMC Truck. I have hard jack stands I can set under the axle. Then a hydraulic lack to ease the back up till the springs float, and start undoing the existing original springs...
Old Mar 25, 2006 | 09:54 PM
idealtrucks's Avatar
idealtrucks
A torch might come in handy if they are pretty rusty. Your going to want to replace your bolts anyway.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
