OBDII Code P0266
Old Mar 24, 2006 | 11:55 AM
uralista's Avatar
uralista
OBDII Code P0266
In the last 2 month I have the following problem on my 03 F250.
The engine starts without problem, but very rough idle the first 5-10 minutes, like running on 6 or 7 cylinders. Scanner tool brings the following error codes :
P0266 " Cylinder 2 Contribution/Balance Fault"
and failures from the crankshaft and camshaft position sensor. But I think the last 2 comes from the rough idle.
I think the injector on cylinder 2 is the problem. Did anybody agree ?
Its a 03 F250 with now 110.000 k on it.
My problem : I live in germany, no official Ford dealers, no warranty, I have
to find the problem and I have to solve the problem.
My 96 F250 with the 7,3 PSD runs 8 years without any problems, the 03 have
broken flywheel, broken exhaust at turbo and now the engine problem......
thanks for helping me
Titus
Old Mar 24, 2006 | 01:02 PM
vloney's Avatar
vloney
yeah, it will probably be #2 injector. make sure you check fuel pressure after you replace it. Spec is 45 psi minimum @wot.
Old Mar 24, 2006 | 04:36 PM
uralista's Avatar
uralista
one more question : Which one is the cylinder #2 ??
Old Mar 24, 2006 | 05:27 PM
dunn6253's Avatar
dunn6253
I am pretty sure that it is the first injector on the drivers side, but you might want to check with some one else on that.
Old Mar 24, 2006 | 07:03 PM
vloney's Avatar
vloney
2-4-6-8 on the driver side-----1-3-5-7 on the pass side
Old Mar 24, 2006 | 10:28 PM
down onthe bayou's Avatar
down onthe bayou
The mechanic at the dealership said the new flash is designed to fix that. Of course they flashed mine, and it has been in the shop for over a week, and they still can't get it to run right.
Old Mar 25, 2006 | 12:57 AM
uralista's Avatar
uralista
Thank you guys, FTE helps me so much here in germany. Just looking on ebay for a injector, I hope he ships to germany.
Old Apr 5, 2006 | 06:09 AM
uralista's Avatar
uralista
Update :
Tomorrow I drive to Mannheim to a Ford Dealer who repairs US Army Fords.
I have detete the trouble code and it doesn´t come back, but the problems
are present.
Maybe it´s the ICP ??
-Or the IPR
On Idle the output voltage from the ICP gones from 0,98 to 1,8 on the cold engine.
After 5 - 10 minutes it´s o.k.
Thanks to Diablo predator with diagnostic mode
Old Apr 10, 2006 | 03:04 PM
down onthe bayou
Turns out my turbo was bad, they replaced it and all is o.k. . The flash seems to be alright. Hope the flash works for you. By the way, I did my time in a-burg, and kitzengin. Drink a hefe viesen for me.
Old Apr 13, 2006 | 05:50 AM
uralista's Avatar
uralista
@ down.....
Hope you enjoy your time in germany. In the summer a " Hefeweizen" is not bad, but now here it is a little bit cold...
Old Apr 13, 2006 | 06:02 AM
Industrial_dude's Avatar
Industrial_dude
I just had a Hef at hooters.... good beer especially with lime
Old Apr 13, 2006 | 09:07 AM
Maxium4x4's Avatar
Maxium4x4
EBAY...... pick up a Ford Truck Repair CD for your year and engine. These are out dated manuals, all you have to do is set your computer date back for these to work.
I have a few spare injectors here if you need them. You will find injectors and turbo's on EBAY for a good price or let me know....I'll ship them to you.
Froh, Ihnen zu helfen.
Old Apr 13, 2006 | 01:36 PM
uralista's Avatar
uralista
@ industrial dude
Hope you enjoy this, is this an american beer ??
@maxium
I already own these cd´s and one injector...yes, from ebay :-)
At the Ford dealer they told me they get the new software in 10-12 days.
I hope this will fix the problem.
Old Apr 13, 2006 | 01:55 PM
Maxium4x4's Avatar
Maxium4x4
If your showing an injector imbalance, that usually points to a bad injector. Let me know if you need anything.......we can send parts your way to Germany.
Ebay is unusual, and a great place for some parts. I picked up a set of injectors because the guy was wanting to recover money he spent after trading in his truck and never installed the new injectors he bought.
basstardo
Feb 11, 2017 05:23 PM
Randy Sheats
Jan 20, 2017 08:31 AM
Rob Snider
Nov 22, 2015 07:06 PM
Robert6401
82
Feb 28, 2011 10:56 AM
rascal810
Apr 22, 2010 10:25 AM
