Rearend chatter on turn accelerating from stop
I have a 2003 F150 SCAB 4.6 V8. 32,000 miles. This has been going on from a couple of months now. Accelerating on a turn from a dead stop, a reasonably sharp turn. I experience a chatter from under truck feels like the rear end. I took the truck in yesterday for 30,000 mile inspecton and complained about the chatter. picked it up several hours later and they said Ford has issued a TSB#04-01-06 the order is to pull the drive shaft and grease splines. This was done and in my opinion it still feels like it chatters on the turn, not always but sometimes.
Does anyone have an opinion on what other item it could be? Time is running out on the warranty so I have to make sure I get it back in time.
Thanks for your help
rear
Thanks for your quick reply are the clutch packs in the rear end and do you know the TSB, what happens if I ignore it will the axel fall out?
you look at the sticker on the drivers door. There should be an axle code listed there. If the code has a letter in it, then it's probably limited slip. Just two numbers, probably open diff.
https://www.ford-trucks.com/article/...de_Chart_.html
You can also look at the tag on the axle. You won't likely see the first number, because they drilled a hole through it to mount it to the axle. So on mine, I only see 73, not 373.
Yep, 3.55 Limited slip. If they do warranty service, you might want to make sure they document it well. There's a chance they might just throw in some friction modifier. That may work short term. But you could be faced with the same issue in 6 months. Then you'll need clutch packs for sure.
the dealer that told you it was the drive shaft aint too bright. if you get chatter while turning it is ALWASYS the LS clutch. you should really have them put the friction modifier in, that will fix quite a few and not temporarily, it is the fix. itf the clutch is damaged now, that is a different story. if they are replacing for free thaen get the clutch if you want. if you are paying, put in $10 of addative and see what you think.
It is under warranty till August 2006 or 4,000 more miles, my complaint to them was chatter from rear end while making a sharp turn from a dead stop. Their fix was TSB#04-01-06 repair order says Check OAIS TSB/SSM's repair as per above TSB Lube Splines R&R Drive Shaft. I have an appointment with them on Tuesday and will hear what they say. Thanks for your input
